[GB][2.11.605.0][Sense3.0]BAMF Forever 1.0.7
The lock ring is sexy.
3d home screen spinning thing?
Widgets look different.
Can you post some screenshots. I'm on g3d beta8 right now and the "spinning home screen thing" is already on there. Does this rom have a screenshot capability built in? I hold power and press home and bada Bing. Screenshot
Re: [GB][2.11.605.0][Sense3.0]BAMF Forever 1.0.6
Yup, no lock ring. And since I still have a PG05IMG.zip on my SD root the hboot automatically loads that and will not let me select the option to go into recovery. Frustrating indeed.
Is there a way to get into recovery not from the HBOOT menu?
have you tried using ADB?
adb reboot recovery
if you don't know how to use it, I think we can find the directions on here somewhere.
Reactions: BostonBeats88
i'm running 1.0.6, the latest radios and can't delete multiple txt messages @ once, I can however delete them individually....is anyone else experiencing this? is there a fix for this?
You assume wrong... Settings > BAMF Settings > CPU Options
well with the kernel it comes with I'm not seeing anything over 1.024 in the cpu options so i'd say it can't be overclocked....
Do we need to wipe cache/data in order to upgrade to the latest release?
I haven't installed 1.0.6 yet but did this build come with a custom kernel to accept overclocking because the previous versions use stock kernel that wouldn't clock over stock 1Gig speed?
Read the changelog in the OP
Uh, that comment wasn't in reference to your question :confused:
Re: [GB][2.11.605.0][Sense3.0]BAMF Forever 1.0.4
Flash a backup of your current Forever ROM... wipe data, cache, and dalvik cache.... install 1.0.2... bootup, start logging in, use MyVerizon and login to that successfully, then start Titanium Backup, make a backup of "Verizon Single Sign-On Engine 1.0.16" app and data... make a backup of 1.0.2 (keep it for history)... restore backup of Forever ROM above.... start Titanium Backup and restore Verizon SSO Engine and Data... it did work for me.
Worked for me too
I'm starting to get frequent rosie redraws. I'm still on 1.02. I guess I should update.
Sent from my HTC Thunderbolt using Tapatalk for your reading pleasure.
francomattia
