[GB][2.11.605.0][Sense3.0]BAMF Forever 1.0.7
Re: [GB][2.11.605.0][Sense3.0]BAMF Forever 1.0.6
if you restored using TitaniumBackup, go in & repair market links to ensure they'll be updated
TB>Menu>More>Market Doctor> "This will scan your installed apps and v erify their android market links. missing links can be repaired...new links can also be created from scratch"
if you already know this, already tried this, or it doesn't apply, then forget i said it :)
the only issues i've had are restoring amazon apps that show as "update available" for the android marketplace (ie Flex T9--i'll go to update and it will deny it, like it should, b/c i downloaded it from Amazon)
I had the same issue and the above directions fixed all my app's.
I didn't know this was available, only the donate version though so I think I just found a reason to buy it haha
If you like what I do buy me a brew.
Case of brew bought and sent.
I've never rooted before (too scared of a brick) but after using Revolutionary and then your ROM, everything works. (well, except for the gallery/edit photo/effects FC's all the time, but small price to pay...).
THANK YOU.
THANK YOU.
If you're having problems with apps force closing... You can use "fix permissions" in ROM Manager.
Anyone having an issue where the GPS is randomly kicking on and running?
Just tried that. Rebooted and gallery/edit photo/effects FCs every time. However, Crop, Rotate Left/Right all work fine. It's just the Effects option that messes up.
I also tried the Gallery/Clear Data under Applications. No help. Also, when installing the ROM yesterday, did the full wipe/cache/davlik et all.
It's the only thing so far that I've found that FCs when using.
Just tried that myself. And guess what? FC. No biggie as I don't do effects, but something that might need looking into.
Just double checking 1.0.6 is a complete rom and not a patch right?
at 309MB it better be a full ROM :)
(i was wondering the same thing until i downloaded it & saw the size)
so far so good
updated: one "end call" bug so far (only 1 phone call. not a good ratio)--applied the Sense 2.0 'Answer Screen' and hoping that does the trick.
this is my daily driver now. enjoy the 5 star rating. peace.
Loaded this up 2 nights ago and have not had a problem since. It looks REALY good. I was really surprised when I saw the different market. So far no FC's on me and everything seems to be working fine. Battery was a tad bit worse then Bamf 4.9 or whatever BUT I think it just needs a day or 2 to settle in. My previous Bamf rom got better after a couple days.
anyone able to get their FFC to show the correct orientation when using either
Google Talk or Google Hangout?
mine will show me sideways.
searched the thread, didn't see any hits w/ "sideways, sideways camera".
thoughts? or is this a known bug of which i've yet to read.
anyone having issues with txts not sending or getting them
out of no where my phone saids its send but the other person never gets my txt or i dont get them iether i have to do a batt pull one a day when i notice its happening
Yeah, I've had this problem since running the original stock OS. I use GO SMS now, and can actually see when they aren't sending (the little arrow just keeps flashing), but when I using the just the regular SMS app, I often wouldn't notice for hours, and wonder why no one was responding to me.
Oddly enough, it has not happened to me (yet) on BAMF Forever...but I'm pretty sure it's either an Android or Thunderbolt bug, rather than one specific to this ROM. At least it has been in my case.
ajr81
