[GB][2.11.605.0][Sense3.0]BAMF Forever 1.0.7
Re: [GB][2.11.605.0][Sense3.0]BAMF Forever 1.0.2
Plan on installing this asap.. I installed 1.0 at work just to give it a look see (NFL working etc) and I like it so far lol..Now I see 1.0.2 is up so here I come!
I am coming from Gingeritis 3D VIII; has anyone noticed that the shortcuts on the Lock Screen are not all that fluid, or is it just me? It's not bad, just seems a little slower and laggy. But all-in-all, BAMF Forever 1.0.x is a better ROM than Gingeritis 3D, mainly due to that fact that NFL Mobile works. My opinion though!
Wow 6-8 hours to download from 2 of the links lol
What is the recommended radio for this ROM?
I don't know if there is any one recommended radio... I'm fairly sure any Gingerbread radio will work... I'm using the latest 2.11 RUU leaked radio and it's working just fine.
I'm running shifts3ns3 no problems, but I've been waiting for a major BAMF release for awhile now. Two updates already! Adrynalyne is a machine with this release. Downloading now :)
Yeah you can install radio before or after installing ROM. Make sure cwm is updated to the latest recovery. Previous versions were not playing well with our Bolts.
there is one thing i want to know about this ROM... is there an "END CALL" bug??? i know the BAMF Preview had it.. i just need to be able to answer my calls.
I have 5.0.2.1
I have another question right now my software number is 2.11.605.0 and my baseband version is 1.39.00.627r, 0.01.69.0625r and I'm running gingeritis 3D. These are not the lastest builds are they?
I have 5.0.2.1
It's not the latest Radios, but it will work with this ROM.
To flash the radio, rename the zip to PG05IMG.zip if it's not already and place it on the root of your SD Card. Boot into Bootloader: power off your phone... Turn the phone back on by holding down the volume down rocker and the power button at the same time until the phone opens in bootloader. The zip should start running and updating the radio. Once done reboot the phone on and remove the PG05IMG.zip from your phone, or rename, or move it off the root of the sd card in another folder. If its not moved after the installation it will constantly keep trying to update the radio if you ever need to boot into bootloader again to get to recovery.
CWM version has NOTHING to do with installing a Radio.
Should I go ahead and update to the lastest?
If you want to... like I said above that radio will work with this ROM.... so you DON'T have to update your Radio.
The 2.11 is the latest GB build, but those are not the latest radios. The link I posted above has the radios from the 2.11 leak. They are the best performing radio combination yet IMHO.
And if you want a full list of Radio... just click on the link in my signature... scroll down past the ROMs to Radio's.. click on the Thunderbolt Radio's link.
Ok updated to the newest radios. Thanks guys. Flashing the ROM as I type.
when i try to pick which albums i want to show or hide in the gallery, the gallery force closes
Since we don't have much information I'll start with the basics... did you just install this ROM... did you do a Wipe Data, Wipe Cache and Wipe Dalvik cache before you installed the ROM???
kos123q
