yep did all that, when i first went to gallery i could view every album then i decided to uncheck some of the boxes, then went back to gallery later to change the settings but then it started force closing
is there anyway to change the shortcuts on the lockscreen? would like to exchange mail for gmail and messages for handcent.
Long press the home screen > Lock screen > scroll to find the (Current) screen > Settings > click the one you want to change, select what you want it to be > Done > Apply.
So tempted to go back to Sense, I've been using DT's AOSP ROMs since trying out Skyraider Zeus 2.1
Switched from gingeritis and its amazing.
going from BAMF Forever 1.01 to 1.02, is it necessary to wipe? also does 1.02 have the MObile hotspot fix integrated?
will this work with the 802 radio?
From what I've been hearing, no, you do not need to do a full wipe to go from 1.0.1 to 1.0.2, but I do recommend wiping cache and dalvik.
The Mobile hotspot fix in NOT included in 1.0.2. Wireless Tether 2.0.7 works fine, and ADR has said he will put it in the next update.
I can't keep radio version straight anymore, but this will work with any of the GB radios (i.e. any post-MR2 radio).
