GB Rom Leaked for HTC EVO
First I did factory reset, wipe cache, wipe dalvik. I did each one twice. What should I see different from stock? When I restore with titanium backup, should I restore all data and apps or just all apps?
So the OP for this ROM initially just released the source code. Then TMartin posted a flashable zip for the ROM, so I believe that is what everyone is using. Anytime you flash to a different ROM you should always wipe Data/Cache/Dalvik before flashing the new ROM. This is fairly standard procedure unless you are flashing to an update version of the same ROM, then wiping Data is not necessary unless the Dev specifically says to do so. You might want to do a full wipe and then try to reflash the ROM and see if that helps with the issues you are seeing.
Aside from those three. I always wipe SYSTEM as well. Is this not needed?
Sent from my evil hideout. MUWHAHAHAHA!!!!!!
I just dl'd and have it running on my EVO :)
When I checked my software information, however I got a baseband version of 2.15.00.07.28 vs 2.15.00.11.19 ( the baseband pictured at the start of the thread). Likewise my PRI version is 1.40_003 vs. the 1.90_003 . How should I go about getting caught up to what the OP had? Thanks!
Nevermind.. Here is the answer:
http://forum.xda-developers.com/showthread.php?t=715485
Not sure what the System wipe actually does. I just read the OP for the ROM and wipe everything they say to wipe. Most say just to wipe Data/Cache/Dalvik. As this is typically what I do, I have never really had an issue getting ROMs to run.
Ok...I just re-installed the Tmartin Rom. This is what I am experiencing. My camera for tango has me upside down to the recipient, I can't select my own wallpaper, my email and text icons don't display the number of messages waiting. It seems like my internet is slower using 3g. My webkit is 533.1, my wife EVO webkit is 3.1. Any ideals on how to fix this. I have searched, but I can't find how to locate tmartin so I can ask him.
Here is a link to his XDA profile. :-)
http://forum.xda-developers.com/member.php?u=1055909
Hey man, I just noticed what ROM your running....where did you find that...I NEED IT!!!! :p
Been running for a week now, just a few issues:
1. Netflix app will not stream
2. video camera FC after recording (recordings not saved)
3. Chase app will not connect/login
Anyone else having these issues? In looking through the posts, it seems that I am not the only one to have an issue with Netflix, but I didn't see anyone else having issues with Chase or the videocamera...
Oh, and YouMail doesn't seem to want to work, but I was having issues there before I changed ROM's so I'm not sure if that is related.
Odgreen
