Got ROMs? Flashable ZIPs for your Alltel MAXX!
What carrier you on? I'll do some builds in the next couple days for you all.
Sent from my XT908 using Tapatalk
Here's a CM10.2 build with working 3G for you Alltel guys. Wifi has some issues getting connected for me, toggling airplane mode it will connect to wifi.
Make sure to use the latest gapps.
The thumb cell guy is still hanging around =)
Thank you so much for keeping up with all this and all your great work!!
Thanks a bunch. Its up and running great so far. Looks like they finally found a fix for 3g. Hopefully it'll get verified soon and merged to CM.
@iaminflames - Is wifi functioning normally for you? This is the patch that got 3g working for those inquiring minds.
@fantasy2c - Here's a CM10.2 build with working 3G for you Thumb Cellular folks.
Yea I stumbled on that patch last night and figured that was the one. WiFi is working fine for me.
I'd love one for the lone Element Mobile person on here. :-) Thanks for all your work on this.
So far so good on Cellcom, only problem I am seeing is no 4G, not a major problem where I am at though because it is a hit or miss anyways (as soon as my contract is up I'm going to Verizon.) I will keep you updated
If you are 4g you'll need to edit the build.prop file. I'll have that info for you tonight.
Here's some builds for the following carriers for you all to play with. Again, all credit and thanks should go to Hashcode, dHacker and Cyanogen team, I just modify a few things for us. As always, what you do to your phone is your doing.
cm-10.2-20131027-UNOFFICIAL-ALLTEL-spyder
cm-10.2-20131027-UNOFFICIAL-CELLCOM-spyder
cm-10.2-20131027-UNOFFICIAL-ELEMENT-spyder
cm-10.2-20131027-UNOFFICIAL-THUMB-spyder
cm-10.2-20131027-UNOFFICIAL-nTELOS-spyder
I'm a little buggier than my 10.1 build was. Data does work but doesn't like to resume after WiFi is turned off. But can manage to get it back. Also force closes on clock, browser, and gmail at times. I'll explore the forums but thinking I may want to re-download and reinstall. Maybe its a bad gapps install? And thanks to Hashcode, and dHacker for not forgetting about the xt908 and to Craptorman for the custom adaptations.
mama baer
