Got ROMs? Flashable ZIPs for your Alltel MAXX!
So far so good on Cellcom, only problem I am seeing is no 4G, not a major problem where I am at though because it is a hit or miss anyways (as soon as my contract is up I'm going to Verizon.) I will keep you updated
Download the spyder build for the Verizon version xt912 and see if 4g works with it.
Sent from my XT908 using Tapatalk
I'm a little buggier than my 10.1 build was. Data does work but doesn't like to resume after WiFi is turned off. But can manage to get it back. Also force closes on clock, browser, and gmail at times. I'll explore the forums but thinking I may want to re-download and reinstall. Maybe its a bad gapps install? And thanks to Hashcode, and dHacker for not forgetting about the xt908 and to Craptorman for the custom adaptations.
Did you use the latest gapps?
Hi there. I got busy, retired from AC and been working on another site. I've been running that CM build and it's been rock solid until recently. I went to transfer back to my stock side (I also need to make use of the micro HDMI which doesn't work in CM) and I apparently deleted it, and all my backups at some point, lol...oops. No bueno. Seeing that 4.3 screenshot was a nice surprise though.
Second try and the propper gapps downloaded from CM website and all is much better.
Hey man good to hear from you, its been a while. Hope all has been well. 4.3 is running great on our RAZR I recommend giving it a try. Hope you can stick around a while.
Thanks! I loaded it on and all appears to be good with the exception of 4G (mentioned already) and MMS. I know I have to use GoSMS but haven't gotten around to installing it or finding the right settings for it yet.
For those with 4G on their XT908 edit the following lines in your build.prop file. Reboot and see if 4G works.
Change these lines to the following...
ro.telephony.default_network=10
ro.cdma.subscription=0
Un-comment these lines (remove # from the beginning of line)
rild.libpath=/system/lib/moto-ril-multimode.so
lte_ril.libpath=/system/lib/lib-mot-lte-ril.so
ril.rat=LTE
ril.rat=LTE
Done - 3G no longer works, 4G works great.
Forgot one line, not sure it will make a difference, change this line to....
ro.telephony.ril.v3=writeaidonly,usevoicetechfordata
The 4G xt908 version appears to be very close to the same as verizon version xt912.
Done, no go on 3G :(
I did try rebooting and trying various 3g settings (CDMA/EvDo auto, CDMA/EvDo/GSM/WCDMA, etc.) and none work. I also wiped the ROM and reinstalled, so this is on a fresh install.
Just wanted to throw this out to all of us on small networks.. I found kernel modules that allow over clocking that seem to be stable found on a different website don't know the rules so I didn't post.. Running cm 10.2 at 1.3 ghz smoothly.. If I can post the link I will if not pm me and ill send the link
levertisbree
