Got ROMs? Flashable ZIPs for your Alltel MAXX!
If you're referring to this patch, it only affects cdma/lte phones. This patch is not in my builds. I'll do another build tonight and have someone with the 4g/lte version of the xt908 to try it.
Dang I swear they're never going to merge the 3g patch
Sent from my XT908 using Tapatalk
These are the 3 patches that got us NV users 3g.
Gerrit Code Review - I see this one has been submitted for cm11 this morning.
Gerrit Code Review - This one had build errors and I had to fix the broken code. The APN info didn't load correctly until this one was applied.
Gerrit Code Review - If "skipdatareg" isn't on the ro.telephony.ril.v3= line in the build.prop file 3G wouldn't work.
Anyone having issues with the WiFi connecting? 1. - It will join a network, but when the phone locks and has been off for awhile it won't reconnect. 2. - If I go home or work it won't automatically connect. It says "Obtaining IP Address". The only way it will reconnect is with a reboot, which I have to do several times a day. I have toggled the settings for "Keep Wi-Fi on during sleep" between "Always" and "Only when plugged in" and also toggled the "Wi-Fi optimization" on and off with no success. I did notice that the MAC address displays Unavailable in both the WiFi settings and the about phone. I am on the CM11 20131201 Alltel build.
Edit:
This doesn't happen every time, but most of the time.
Been working perfectly for me. Notsure if this will help since it works sometimes. Open terminal app and type the following. Su <enter> then wifical.sh <enter>.
Thanks, tried it, then wifi disconnected and wouldn't reconnect. Had to reboot to reconnect. Then went home and phone would connect there either without reboot. Strange, works fine on stock rom...
How's battery life been for everyone? Mine has been a bit worse than when I was on 4.3. I used to be around 90% at noon and now I'm usually around 85% at noon.
Using CPU Spy I noticed it was never going into deep sleep mode. If I reboot after flashing rom it wil go into deep sleep mode and battery life is noticably better.
Looking at CPU spy I'm getting no deep sleep.
Try booting into stock slot and then right back to CM11 slot. Seems to work for me, just rebooting CM11 doesn't always fix it. The lower battery life sucks when you know what I should be like.
Loving these builds; hating that I don't have a new AT&T phone yet. Anyone have any news on that?
Seems sending an SMS to a shortcode in the latest posted KitKat build causes com.android.phone to force close repeatedly and I have to reboot the phone.
Wi-Fi has been fine. Had a couple random drops in mobile data though that a reboot fixed.
Enabling ART seemed fine at first but ended up causing numerous cases of general instability, so I switched back to Dalvik.
I may be the only one having to reboot after turning WIFI off to get data back. But in case someone else is I found that if I turn off data, then start WIFI I can get data back when done with WIFI by turning off WIFI then turning data on. These are very good builds.
I finally reinstalled the 12/1 cm11 build. This seems to have fixed the issues I was having with moving from one wifi network to another, but was still experiencing issues resuming wifi from sleep. So after the reinstall, the setting keep wifi on during sleep set to always worked (which did not before).
However, I still have my MAC address listed as Unavailable both in Advanced Wifi Settings and in About Phone / Status. Anyone else seeing this?
CPU spy says I'm getting into deep sleep but battery life is almost half of what it should be...something isn't right although everything else is working fine here
Same here. Only got about 13 hours yesterday which is less than half of what I usually get.
I got a good one..lost some the droid ringtones that came with this ROM and also now have a performance button in the settings menu that was never there before..buddy doesn't have these things same phone same ROM? I wiped all four settings in safestrap Before flashing so Idk what the deal is. Is it because I set up rf in settings instead of format? Itvalso saved all my WiFi passwords ROM to ROM even after a full wipe
Nazeer zaheen
