Got ROMs? Flashable ZIPs for your Alltel MAXX!
The Performance section has been there since CM10. As far as WiFi passwords go, you probably told the phone to restore data from your Google account during setup.
Sent from my XT908 using Tapatalk
Performance has been then for a while on all cm builds but I think it only shows up if you unlock developer settings
Is there any way we could make a patch with the files that need replaced to make 3g work so we could just patch over new cm nightlies?
Yes and no. All the telephony stuff is in the frameworks and the frameworks stuff is always changing. Right now with the lastest telephony commits 3G doesn't work for me. Two of the patches I used were merged but then reverted with alot of code changes that left 3g not working for me. That's why I haven't posted any new builds, hoping things get sorted out in the telephony area.
I don't get many calls but recently have had a few and messages left. I now see Element's voice mail is accessed with my phone number and not *86. Is it possible to change this or does it have to be built into the ROM? I try changing it in settings but it doesn't stick. I can get voice mail messages but only after a reboot. Now the voice message indicator won't go away even after I delete the message. Any suggestions would be great. Still loving the build.
Yea I saw one new 3g "fix" merged yesterday so I tried the newest nightly. I made the proper build prop changed needed and had 3g on first boot but never had it again after that.
It's built into the ROM. Can you guys chime in her and let me know what each carrier's voicemail # should be. *86 or your 10-digit phone number. I'm running a 4.4.2 build from today with working Wifi-hotspot and kernel tweaks by Stargo (Droid 4 builds) that may fix the no deep sleep issue and some power management improvements. He's really stepped up and keeping the developments going. Jump of there and give him thanks. :)
If you all can update me with the voicemail number settings I'll crank out some builds for you to play with.
I'm not sure what alltels is since I use Google voice
Sent from my Nexus 7 using Tapatalk
Interesting, guess I better try the same and see what I can come up with.
Yea I was pretty excited earlier when I installed the 12/16 nightly and had 3g on first boot. Then 10 minutes later it was gone and I had no network connectivity.
Gerrit Code Review that's the newest 3g patch that was merged yesterday. It should allow forced 3g connectivity instead of only transition from LTE to 3g like before.
It appears NV is the issue. SIM/RUIM phones have 3G working. It looks like its not getting the info from NV. Starting to learn more and understand the code a little better.
Yea and unfortunately we are the RAZR users using NV
Element is the 10 digit phone number. I think I told you that wrong earlier. Sorry about that. We used to be Alltel and I don't think much really changed. If that helps. We also are somewhat connected to Verizon as mobile to mobile is free with Verizon. My area should have become Verizon but the tower owners in my area decided to start their own company, ie Element. That may be meaningless but thought maybe it would mean something to you guys that are better at this than I am. Element will all be ending this year as we get bought out by AT&T and switched to GSM.
Yep that's all the same as alltel. We are all changing to AT&T. Should be interesting.
Going to redownload to see if I got a bad download first download failed as soon as I swiped to install
What error did it give you? You need SS3.65 to flash the new builds.
A status 6 ..OK I do believe I have 3.11 I'll grab the update then.
Safestrap was definitely the issue
Gasho
