[GUIDE] Optimus V ZVJ
yes, I did all of these. The profiles have all of the information in them, as well, but still no data on the phone.
later tonight I'm going to go back to zv9 and see if I can backup all of my data information while it has data capability, and then go back to zvd and see if I can figure out why it wasn't working.
just hopped on to zv9 and now I have working everything without doing anything else. hmmm. I don't know. I'm take pictures of every data screen hahah.
Hmm.. Weird you did have data working on it before right? Open QPST and read your phone then save to file. But don't count on it for ha and aaa keys.
Sent from my VM670 using Tapatalk 2
this is what i do after writeing the .nvs file to zvd to get data back
To Restore Data on LS670 Firmware:
1: Install anycut.apk
2: Run anycut and "create shortcut"-"Activity"-"LG HIDDEN DATA" and hit ok
3: Return to desktop and open the shortcut
4: go into CDG2 Data Settings and change PPP CARRIER from Sprint to Undetermined
5: Hit back and the phone will reboot
6: Open Qpst service programing and hit Load from file
7: Select the .qcn file you saved durring prep
8: Select write to phone and enter your spc
9: The phone will reboot
10: Open LGNPST and Select "Phone Setting" Enter your Spc hit ok then Read
11: Close lgnpst and open DFS and enter your Spc and click SPC
12: Click the Programing Tab then the Mobile IP TAB and click Read
13: On the first Profile Uncheck the boxes next to Enter value in HEX for both AAA Shared Secret and HA Shared Secret
14: Clear anything there and click write current profile settings
15: go to profile 3 and Uncheck the Enter Value in HEX box for AAA Shared Secret and Copy the value
16: Go To profile 2 and Paste that value into AAA Shared Secret box and Enter Vmug33k for HA shared Secret
17: Hit Write current profile settings and switch to the data tab next to mobile ip and hit read
18: under HDR AN and HDR AN Long you'll see YOURMEID@mdata.vmobl.com with PWD boxes under them
19: Paste your AAA Key that you copied earlier into both pwd boxes and hit write
Reboot Phone and you will have Data
I'm back at zv9 now and actually, I had never created a .qcn backup. But I thought of that like an hour ago and made one for tonight when I try again :) I think that's what my problem was.
It's not part of the guide just what I do...
Not too bad really...
Edit: supposed to be a screen shot here.. Hmm
Edit2: well anyways I ran speed test .net app and on zvj I get 267 ping 1094 down 797 up
Tapatalk'n it from my VM670 running LS670ZVJ Dante Rom
For me... It varies but this would be on the high end
worked FLAWLESSLY. I think it was the .qcn thing.
Okay, so new problem. After moving up to zvj, everytime I try to root it with the optiauto tool, I get these errors when attempting the exploit.
Code:
Installing persistent root... write: No space left on device
Done
Waiting for filesystem to sync... Done
Installing Recovery - Xionia CWMA... write: No space left on device
Done
Installing Misc - Clean... write: No space left on device
Done
---- END LOG ----
I followed the directions to a T, and I'm not sure what the problem is.
Code:
Done
Done
Done
---- END LOG ----
Someone who owns an optimus s got the same errors, i'm not sure what they did though...post in the thread saying you are running optimus s firmware.
try factory resetting first.
I'm becoming a pro at putting the zvd firmware on my V and getting everything working. Just did it for the fourth time this morning. took 15 minutes for the entire process. win. Now if I could just successfully get zvj rooted, I'd be happy.
I tried factory resetting it and wiping cache, but that didn't work. :( I don't know why it keeps saying that. It's very frustrating. AND, I have better service while on zvj. So I really want to get this rooted.
Your not missing the part where you run update.zip again and it fails (expected) are you? It says out of space... Is your sdcard full?
rosannejoy555
