[GUIDE] Rooting 3.7/Hboot2.02+ w/screen shots (1/27/2011)
after i type in
it doesn't do anything and i can't type or hit enter. just sits their
Don't try to do anything, it's still copying, note the screen shot and seconds it took for the transfer:
Reactions: joey132
i got a phone call and had to unplug my phone ,damnit!
im going to reboot my phone again and try all over just incase it messed up
k i got all the way to 9 all by myself YAY!
9. Backup your 4G RSA keys (in command prompt, at the #) – The following three commands will create this directory: nandroid/RSA-PR-BACKUP on your sdcard, inside of that directory will be this file: wimax.img, that file is a digital image of the partition on your phone which holds your 4G keys.
ok i see the keys at the bottum but what do i do with them next?
^^ what the hell did that just say
It's just that it backs up the 4G keys to your sdcard.
You don't need to do anything with them, they are there just in case they get erased.
Reactions: joey132
im guessing i can skip step 10 as well since it the same thing and now i just hit enter at the #
how do you guys temproot?
Ive tried using z4root 1.3 on my evo and it says its been temp rooted, but when I go to titanium backup it says there is no root access. I have also tried downloading and installing busybox from titanium backup.
Are there any other ways?
I basicly just want to backup all my apps and settings so after the root I can return the phone to where it was before being wiped clean.
If that is your goal, using Unrevoked3 is a lot faster & simpler process that will give you root without touching any of your current data.
Reactions: joey132
11. Change permissions and flash some system version information: (this is still done in the command window, at the #, press Enter after each line)
Quote:
chmod 0755 /data/local/flash_image
./data/local/flash_image misc /sdcard/mtd-eng.img
sync
do i need to do this or can i just go and reboot my phone
sync
You need to follow each step 100%. That is why they are there.
Reactions: joey132
hey im on step 15 and im on the prompt again and the last sentence it says "failed: no such file or directory"
Do you have more than one instance of ADB running or any programs running on your computer talking to your phone? Like DoubleTwist, etc? If HTC sync is up and running in the lower right of your computer, right click on it and exit it.
Your commands aren't being executed properly.
ok i figured out what was wrong.
now im on 18. 18. Select Flash zip from the recovery menu and choose “unrevoked-forever.zip”, after installation is complete, select Power Off.
i can't move nothing on my phone at the moment after i renamed the files.
it shows the evo and a red triangle sign on front and under it says
Build: Not Set
enabling usb-ms : .
USB-MS ebabled!
Press power to Disable.
and return to menu
dumpsterrentals89
