HELP! MMS Problem via Gingeritis 3D Beta VII
Jan 16, 2011
9
Aloha,
I'm not sure if this problem has occurred with anyone else running a different ROM other than Gingeritis 3D. I 'was' running on Gingeritis 3D Beta VII until I came across a minor problem (I guess... :confused:).
Anyway, I noticed that every picture message I sent/received, turned out to be blurry and junky. The max resolution for pictures I receive via MMS is 480x360--same quality when I send out as well. So I wiped data/cache/dalvik cache and re-flashed the ROM thinking it would fix my problem but it's still the same. I'm irritated now, lol.
So to temporarily fix my problem, I reverted back to Beta VI, and have no problems via MMS...pictures sent/received are over 3MP =). Though, I do miss Beta VII...it seems a lot smoother than Beta VI. Is there any solution to this MMS problem? I would love to go back to Beta VII =D!
Thanks in advance!
Linda
I haven't had that issue. But I did have an issue with the shade of green that was used for revived messages. I just switched to Go Sms
AS1890
