Help understanding this phone
so i wouldnt have to disable the lagfix in voodoo or anything to flash it...just making sure dont wanna funk up the phone..already thought i did a couple times and was doubting my abilities to follow instructions lol
If you are already on a voodoo kernel, you do not have to disable voodoo lag fix before flashing another voodoo kernel. Just make sure it is a voodoo kernel as quite a few of the kernels have both a voodoo and non voodoo version. If you are wanting to revert back to a non voodoo kernel, you must disable lag fix in CWM, the reboot the phone to let the conversion happen, then boot back into CWM to flash the non voodoo kernel.
ok shark..been letting the phone do its thing lately n battery still sucking dry..so i turned airplane mode on and it didnt drop n like an hour...wucha think will help it..right now i use it only on wifi thinkn bout switching if i can get this battery to hold out..also is there any difference in tsmmarket and the og market?
As far as the battery, check to make sure you have GPS turned off when you are not using it. Also, if you are not connected to a wifi network, turn wifi off since your phone will constantly be searching for a wifi network if it is not connected to one. The tsm market is a themed market. You can still get all the same apps from the tsm market. The difference being with the new market that is out, you can also download movies and books.
Yeah everything is off and the only time it hokds a legit charge is if i put it n airplane mode..anything else and it drops fast...should i wipe battery stats like some peopke are saying? I see the option to in cwm but wanna make sure first
wobblefix
