help with .595 flash fail(prob on my part)
rocksbg
13
I have a rooted DroidX on froyo and tried to flash .595 deodexed from froyo stock(1st rom I have flashed) ... I wipe/reset 3X's and wiped the dalvik too... then flashed the .595 .zip and rebooted... now the grey/white "M" comes up for a few seconds then I get a .5 sec vibrate and then it boots over.. Is this bootloop or do I wait it out another 5-10 minutes of this... I never get the droid eye to come up....
Reactions: 19mitch79
You cannot go straight to GB 595 from Froyo. You must first flash to another version of GB. I would recommend GB 588 because it also updates the baseband. After you flash to 588, then you can flash to 595.
You guys are awesome! That is what makes this community so great. I was having the exact same issue. I have tried so many different fixes. I tried bootstrap for the x and droid 2, flashed 595 deodexed and odexed, wiped cash, wiped data, etc.... So frustrating!!!! I have been working on this for half the damn day and I must say that I am a pro at sbf'ing back to stock!!! And to think that all I had to do was upgrade to an earlier version of gingerbread. Thanks guys!!!
big upps... thanks for the help... finally got the sbf to work right... didn't know I had to have the .sbf file in the rsdlite folder.... doh... live and learn...
Thanks a bunch
DigiMob app
