How can i make my samsung galaxy S3 battery life last longer?
But I read in many blogs and it is always suggested to never use any Battery apps or Task killing apps.
Plus I think this constantly sucks your battery in the background.
Task killers bad, some battery apps good.
Just plug your phone in every night and stop worrying about it! If you really, really, really can't charge your phone routinely, invest in a higher capacity battery or some spare batteries. But your looking at 30 hours or more on a charge based on your screen shots. How much do you really need?
Not only that, energizer makes a small rechargeable battery that fits on a key chain that you can use for a quick charge if needed.
Well, I got the Samsung Galaxy S3 Mini for a month now. I know it's not the same phone, but for this thread it comes close enough :o)
My battery life went up to about 29h, starting from 21h, by just a few adjustments and a few free apps :o)
I've installed the Llama app, just to automate a few switches for me. The main part is managing my network connectivity and switching sound profiles (of course, that latter one doens't really apply to this thread). Basically it comes down to this:
  • When my screen is turned off, the WiFi and Mobile Data are disabled after 5 mins. This allows me to finish a download and prevents from losing connection when I accidentaly hit the power button.
  • When my screen turns on, network connectivity is restored
  • When WiFi is connected for at least 30 sec, the mobile data is switched off. This prevents coninuously switching when I'm passing the WiFi router a few times and getting back out of range.
  • When my screen stays off for longer periods, network connectivity kicks in for 2 mins every 30 mins to allow a few data syncs (and it keeps switched off at night at home).
Depending of time and location, it also changes my screen brightness (I don't have that auto brightness feature).
I've also reviewed my sync settings. I've disabled all background syncs except Google Calendar and GMail. Auto sync only occurs when I've got WiFi network connectivity.
I've also installed the Battery Doctor app, but more to get a time reading of my remaining battery power and for charge management. I don't really use its power saving options because Llama handles almost all of it a bit more flexible. I use the optimize function only once or twice a week, just when I want to clean up properly. Once or twice a day, I clean out the recent apps log (hold home button), because that closes a few apps who would otherwise reside passively in the memory and use battery power that way.
I only turn on GPS when I need location based services (Llama uses cell polling), like for navigation, Google Local, ... I would have automated it in Llama, but in Jelly Bean that will only work if I root my phone and for now I've got no intention to do so.
And just keep in mind that screen time and network time consume lots of battery power. When you take some moderation, the battery could easily last through the day.
Cheers!
Hi,
Correct me if I am wrong, but I have read that, with heavy usage Samsung GS3 battery would last for around 14-15 hours. I am very upset :( with my GS3 battery backup (GT-I9300 on Vodafone GSM India). The phone is brilliant :D . Bought it few days ago from Samsung e-Store India.
My battery lasts for 4-6 hours heavy usage :'(
I Played Temple Run 2 and Iron Man for around 30 min each = 1 Hours
I had data on for around 4-5 Hours (I have 3G but currently speed has been reduce to 2G as I have used up all the 3GB of 3G data allowed). During this I downloaded 2 apps from play Store around 4 to 5 Mb. And Also my Work Email and Gmail is synced (Not sure if this may reduce battery life) :confused:
Yes I have a Live wallpaper On, and Sadly my Colleague love to stare at it... But since she it prettier than my wallpaper I let her stare at it :-[ . Around 10 min.
Also I Dialled 4-5 calls for around 2-3 min each.
That rounds up to around 1hr + 5 hr + 10 min + 20 min = 6:30 min (after which my battery was 8%) :mad:
I am chgarging my device for the Third time now... :'(
Please help me figure out, if may be I am just abusing my GS3, or should I take it to the Service Center.
Please see the screenshots:
Priyanka,
Dude you may not be knowing but Iron Man is such a battery drainer that even my ipad which has 11,600mah battery drops its battery level very quickly. Then live wallpaper consumes so much battery. I put so many live wallpapers before and each time I saw live wallpaper was the second thing what's was draining battery after 'screen'.
Then I would advise if you don't need mails you must disable Gmail service, setting---accounts---gmail---disable sync.
Plus, if you haven't enabled Power Saving Mode on then do it, helps to save a lot of battery.
And I do hope you aren't using wifi as the main network.
Dont use any task killer or battery saver because mostly they are running in the background.
Sent from my GSIII
Delay the sync, turn off GPS, WiFi until needed, turn off Bluetooth until needed. lower screen brightness, no live wallpaper. Get a phone charger for the car, carry around an energizer emergency phone charger for mobile phones, buy a bigger battery. There are lots of things to do to get a good amount from your battery.
RAM being utilized in Android is a good thing and is not in and of itself indicative of anything being wrong.
Live wallpaper isn't that bad unless you spend hours looking at it.
Sent from my SAMSUNG-SGH-I747 using AC Forums mobile app
Text
If you're still having issues after that, charge the battery to 100%, let it discharge to about 50%, then do some screen captures:
+ Go to Settings / Battery, and capture that screen.
+ Tap the line that says "Screen", and capture what that displays
+ Go back to the Battery display, and tap on the graph. Capture that screen, too.
Then post all three of them here.
I followed advice in quoted post. I interpreted the instructions that I should not use my phone while it goes to 50%, despite this I had to use it a little today which was making one call, looking up some buss departures, checking my gcal once. In addition I unlocking screen maybe 6-8 times (unlocked for a couple of seconds, touched screen at 2 of the occasions). If I should have used my phone as I normally do I'll redo the procedure - this is my big pet peeve. Just from taking these screenshots and uploading (mobile data) to dropbox battery dropped from 50% to 48%. That was about 5 min ago, I just unlocked and now it's at 46%! Phone was bought in june 2012 and I remember thinking battery time was bad from the get go, this in addition to it only being 1 year old makes me belive it's not natural degradation of battery that is responsible for the current situation. It might be faulty, some app/screwed up ROM, or it's just normal performance for the S3. If so I'm saddened, but need to hear it so I can stop wasting time investigating and trying to remedy.
Stock ROM 4.1.2
Removed a lot of system apps (I know, should have frozen them). All where safe to remove according to sources.
Frozen almost all apps I don't use frequently, and some other system apps I deemed unnecessary.
Mastersync enabled always as well as mobile data. I'm not interested in having them periodically disabled.
For the last month power saving mode disabled, but before that enabled and I don't feel there's a difference battery wise.
Wifi on during sleep - Always, for the last month. Conflicting advice, some say disabled some say enabled. Although I never use WIFI.
Wifi timer disabled
Bluetooth disabled
GPS and all three location services disabled except when that rare occasion.
Screen time out 30 seconds, smart stay disabled (not that I think it drains battery); I'm always fast to lock manually.
Haptic feedback disabled
Auto brightness off - this is probably a key factor draining battery for me, I usually forget to turn it down from 100% (needed outside). But still i feel something else is amiss.
Installed apps
* indicates I have it frozen practically always: My Installed Android Apps Device Summary
Device: samsung GT-I9300 Android Version: 4.1.2 Build: JZO54K.I9300XXEMA2 Applications Installed: 112​
List Generated By: MyAppsList (web download | mobile download)
All packages and apps, including non-google-play ones:
Code:
root@android:/ # pm list packages
package:air.se.svt.svti.android.svtplayer
package:android
package:android.googleSearch.googleSearchWidget
package:at.abraxas.powerwidget.free
package:be.bdwm.clipsync
package:com.adobe.flashplayer
package:com.adobe.reader
package:com.afterhoursdevelopers.android.synker
package:com.afterhoursdevelopers.android.synker.key
package:com.alarmclock.xtreme.free
package:com.alensw.PicFolder
package:com.anddoes.launcher
package:com.android.MtpApplication
package:com.android.Preconfig
package:com.android.apps.tag
package:com.android.calendar
package:com.android.certinstaller
package:com.android.clipboardsaveservice
package:com.android.contacts
package:com.android.defcontainer
package:com.android.inputdevices
package:com.android.keepass
package:com.android.keychain
package:com.android.mms
package:com.android.musicfx
package:com.android.nfc
package:com.android.packageinstaller
package:com.android.phone
package:com.android.providers.calendar
package:com.android.providers.contacts
package:com.android.providers.downloads
package:com.android.providers.downloads.ui
package:com.android.providers.media
package:com.android.providers.partnerbookmarks
package:com.android.providers.security
package:com.android.providers.settings
package:com.android.providers.telephony
package:com.android.providers.userdictionary
package:com.android.settings
package:com.android.settings.mt
package:com.android.sharedstoragebackup
package:com.android.smspush
package:com.android.stk
package:com.android.systemui
package:com.android.vending
package:com.android.vpndialogs
package:com.antutu.CpuMasterFree
package:com.appspot.eikatou0.ss
package:com.appstar.callrecorder
package:com.arcsoft.picturesbest.app
package:com.asksven.betterbatterystats_xdaedition
package:com.asrazpaid
package:com.banana.alibi
package:com.bankid.bus
package:com.bluefirereader
package:com.boycoy.powerbubble
package:com.browsertexting.android
package:com.bumptech.bumpga
package:com.carrotapp.smscleanerpro
package:com.chrome.beta
package:com.dama.paperartist
package:com.devhd.feedly
package:com.dgo.VitalPlayer
package:com.droidware.uninstallmaster
package:com.dropbox.android
package:com.dv.marketmod.installer
package:com.ebay.mobile
package:com.eniro
package:com.estrongs.android.pop
package:com.evernote
package:com.facebook.katana
package:com..android
package:com.fmm.dm
package:com.fmm.ds
package:com.foxfi
package:com.funanduseful.earlybirdalarm
package:com.google.android.apps.chrometophone
package:com.google.android.apps.maps
package:com.google.android.apps.translate
package:com.google.android.backup
package:com.google.android.calendar
package:com.google.android.gm
package:com.google.android.gms
package:com.google.android.googlequicksearchbox
package:com.google.android.gsf
package:com.google.android.gsf.login
package:com.google.android.location
package:com.google.android.partnersetup
package:com.google.android.street
package:com.google.android.syncadapters.bookmarks
package:com.google.android.syncadapters.calendar
package:com.google.android.syncadapters.contacts
package:com.google.android.voicesearch
package:com.google.android.youtube
package:com.handcent.nextsms
package:com.handyandy.ringleader.pro
package:com.incorporateapps.spoty
package:com.intangibleobject.securesettings.plugin
package:com.jarman.vemringde
package:com.joaomgcd.autoshortcut
package:com.kantaris.playse
package:com.keramidas.TitaniumBackup
package:com.keyes.screebl.lite
package:com.legendk.multiwindow.full
package:com.liato.bankdroid
package:com.logmein.ignitionpro.android
package:com.lylynx.smsscheduler
package:com.markupartist.sthlmtraveling
package:com.maxmpz.audioplayer
package:com.maxmpz.audioplayer.unlock
package:com.meecel.feedreader.RssDemonAd
package:com.metago.astro
package:com.mrnumber.blocker
package:com.mxtech.ffmpeg.v7_neon
package:com.mxtech.videoplayer.pro
package:com.netmanslab.sa
package:com.ninegag.android.app
package:com.noinnion.android.everclip
package:com.orange.authentication.simcard.permission
package:com.punsoftware.backup
package:com.rayy.android.editad
package:com.redphx.deviceid
package:com.samsung.android.providers.context
package:com.samsung.groupcast
package:com.samsung.rcs
package:com.samsung.scrc.idi.server
package:com.samsung.sec.android.application.csc
package:com.sand.airdroid
package:com.sec.android.Kies
package:com.sec.android.app.DataCreate
package:com.sec.android.app.FileShareClient
package:com.sec.android.app.FileShareServer
package:com.sec.android.app.FlashBarService
package:com.sec.android.app.SecSetupWizard
package:com.sec.android.app.camera
package:com.sec.android.app.clockpackage
package:com.sec.android.app.controlpanel
package:com.sec.android.app.factorymode
package:com.sec.android.app.launcher
package:com.sec.android.app.lcdtest
package:com.sec.android.app.minimode.res
package:com.sec.android.app.music
package:com.sec.android.app.myfiles
package:com.sec.android.app.personalization
package:com.sec.android.app.phoneutil
package:com.sec.android.app.popupcalculator
package:com.sec.android.app.popupuireceiver
package:com.sec.android.app.selftestmode
package:com.sec.android.app.servicemodeapp
package:com.sec.android.app.sns3
package:com.sec.android.app.sysscope
package:com.sec.android.app.tmserver
package:com.sec.android.app.twdvfs
package:com.sec.android.app.videoplayer
package:com.sec.android.app.voicerecorder
package:com.sec.android.app.wallpaperchooser
package:com.sec.android.app.wlantest
package:com.sec.android.cloudagent.dropboxoobe
package:com.sec.android.directconnect
package:com.sec.android.directshare
package:com.sec.android.dttsupport
package:com.sec.android.favoriteappwidget
package:com.sec.android.fwupgrade
package:com.sec.android.gallery3d
package:com.sec.android.inputmethod
package:com.sec.android.magnifier
package:com.sec.android.preloadinstaller
package:com.sec.android.provider.badge
package:com.sec.android.provider.logsprovider
package:com.sec.android.provider.smemo
package:com.sec.android.providers.downloads
package:com.sec.android.sCloudBackupApp
package:com.sec.android.widgetapp.SPlannerAppWidget
package:com.sec.android.widgetapp.alarmclock
package:com.sec.android.widgetapp.diotek.smemo
package:com.sec.android.widgetapp.favoriteswidget
package:com.sec.android.widgetapp.webmanual
package:com.sec.app.RilErrorNotifier
package:com.sec.bcservice
package:com.sec.dsm.phone
package:com.sec.dsm.system
package:com.sec.enterprise.permissions
package:com.sec.factory
package:com.sec.hearingadjust
package:com.sec.pcw.device
package:com.sec.phone
package:com.sec.setdefaultbrowser
package:com.sec.widgetapp.dialerwidget
package:com.shazam.android
package:com.silenthoursnew
package:com.smlds
package:com.texty.sms
package:com.touchtype.swiftkey
package:com.ttxapps.dropsync
package:com.tvkdevelopment.nobloat
package:com.twitter.android
package:com.usk.app.notifymyandroid
package:com.viber.voip
package:com.vimeo.android.videoapp
package:com.willdev.mailalert
package:com.wsomacp
package:com.wssnps
package:com.wte.smseditor
package:com.wunderkinder.wunderlistandroid
package:couchDev.tools.DocxParser
package:dk.tacit.android.foldersync.full
package:eu.chainfire.cfroot.cwmmanager
package:eu.chainfire.supersu
package:goldenshorestechnologies.brightestflashlight.free
package:hotspotshield.android.vpn
package:hu.tagsoft.ttorrent.pro
package:info.guardianproject.browser
package:jackpal.androidterm
package:jp.co.asbit.pvstar
package:keepass2android.keepass2android
package:la.droid.qr
package:name.markus.droesser.tapeatalk
package:net.dinglisch.android.filer
package:net.dinglisch.android.taskerm
package:no.nrk.yr
package:org.adaway
package:org.chip2n.flashbacklite
package:org.mozilla.firefox
package:org.openintents.filemanager
package:org.simalliance.openmobileapi.service
package:org.torproject.android
package:org.transdroid.search
package:org.videolan.vlc.betav7neon
package:se.appcorn.Blocket
package:se.fpt.ft
package:se.ratsit.android.app
package:se.skandiabanken.android.wallet
package:stericson.busybox
package:tv.ustream.ustream
package:uk.co.connorhd.android.linkpush
package:vu.de.urpool.quickdroid
Unfortunately, your screen captures didn't come through. If you're not connecting to WiFi, you should turn it off. WiFi is more efficient for data transfer than 3G or 4G, but if you're not using WiFi you're just powering 2 radios by leaving it on.
Screen brightness can make a huge difference. That big, bright screen is probably the single biggest power user in the phone.
And I apologize for not being clear. You can use the phone normally while waiting for it to drain. In fact, that's probably better, as it may show which of your normal apps are causing a problem.
I've found Juice Defender to be somewhat helpful, not a day & night difference but helpful nonetheless. My 4G has been disabled since I got my phone due to network issues AT&T was experiencing in mid January and I've never re-enabled it. I found even when tethered to my PC I was satisfied with the page load times. I like how much faster 4G is over 3G, that is a night & day difference but I'm willing to compromise the speed for better battery life.
I was unclear as well, naturally I have WIFI disabled. Fixed the screenshots, will do the procedure again tomorrow when I use phone as I normally do. Will have brightness fixed at 50%.
Wait? 22 hours on 50% battery? If that's anywhere close to typical I'm not sure what your concern is. That's about as good as you could possibly hope for.
I downloaded juice defender but the problem with free version was all the radios were switched off while some urgent message was waiting for me.
Either you disable it or keep ur radios off when idle. So i had to disable it.
If you know how to fix it plz explain alo g with a screenshot.
Sent from my GSIII
spade20
