How is Nougat so far?
The only app that has some weird glitching for me is chrome every now and then.
Looks like it is the word "doze" that is the culprit.
Ah, NOW I understand what you meant in your earlier post when you said that you were 'searching' for information on doze in 'Help and feedback' - I thought you were looking at all of the different Settings pages for something related to doze; you were actually searching for the term 'doze' within 'Help and feedback'.
And when it returned a result you selected it. Here's the translation if you're interested (Japanese to English) :
To use the battery saver mode
The remaining battery level is reduced, to save battery power when not immediately charge a smartphone or tablet, you can turn on the battery saver mode. Automatically battery saver When the remaining battery power is low, you can also be set to be turned on.
If the battery saver is on
When the battery saver is turned on, the upper part of the screen and the bottom of the screen will change to orange.
In battery saver mode, the following operations at the terminal in order to save battery life is limited.
You can not use the Google Maps Navigation
Vibration, position information service, is limited most of the background data
App to synchronize, such as e-mail and messages may not be updated and does not start
To turn on the battery saver
You can [Quick Settings] or from the terminal of the Settings app  turn on the battery saver. [Battery]   tap the battery saver].
To turn on the battery saver, (it can be turned on at any time) [ON] and then tap the switch of [OFF].
To configure the remaining battery power is low become When the battery saver is automatically turned on, [automatically ON] Tap, [the battery is 5% or the battery is 15% select the.
Tip: The Android 6.0 or less, and then tap the battery]   [other]   [battery saver].
To turn off the battery saver
In charge of the terminal, battery saver will automatically turn off. By tapping the switch to [ON] and [OFF] of the terminal, you can also turn off the battery saver.
Related Links
Increase the life of the little battery of remaining amount
Increase the life of the battery
To check the remaining battery power
Consumable too early of battery
Was this article helpful?
Yes No
So far I'd say the battery life under light usage is outstanding. It was on my nightstand for 9 1/2 hours last night and lost 3%.
That's what I don't get. Same hardware, same OS, dramatically different results. My usage hasn't changed. Conundrum...
My only problem is Hangouts keeps force closing now. Going to try uninstalling and reinstalling.
Otherwise, everything runs smoothly, I'm catching cats left & right (lolz), notifications look and respond beautifully, I love being able to do basic windowing of apps side-by-side, I love filtering blue light at night in bed before I sleep when I'm listening to Pocket Casts... <3
Hangouts freaking sucks. I never thought understood that. I had force closing on M and yes now on N. Google app and doesn't play well with stock Android. No got google, not good.
How many of see that when you try to get into recovery mode with 7.0 that the text is red and there is nothing that will appear? It seems to be an issue with the current build NRD90M.
I'm not seeing that at all. I see the normal Android on its back with 'No command', then when I press the correct key sequence I see the usual Recovery screen in blue. I did this twice just now, and I've done it half-a-dozen times since I downloaded the release build.
Sounds like your recovery may be corrupted - perhaps you should load the full build from scratch.
Has anybody who is/was NOT in the beta receive the update via OTA yet? Basically just us regular folks :)
I haven't... I'm still waiting. Don't want to side load, flash update, etc. :(
I just signed up for the beta, got the ota in minutes, downloaded, then opted out of the beta. It says you will be factory reset, but it doesn't. All is good.
Can someone post something other than 'battery life' on Nougat ? This is like the term 'battery life' itself would be ashamed & afraid of how much times it gets poked by everyone on forums :D
'Doze-on-the-go' was not the only feature of Nougat, I suppose. Battery needs some days to settle in, IMHO).
Elizabeth78
