[How to] 1-Click-Red cwm for Mac users (No bootcamp or windows required)*update 3/1*
Status
Not open for further replies.
i dont understand that question
everything that I have downloaded; the mega upload item you just sent me, super clean 2.8, clockworkrecovery red; they were all in a download folder within the sdcard : /sdcard/downloads/....I moved all of those files to the main part of the sdcard : /sdcard/
Just did recovery and did update but same thing happened again.
what exactly is it that happened?
Braydon is trying something out hopefully it works and we can try it out for you,,,,are you running tiger or leopard?
it quickly starts a download bar with an arrow coming out of a box...but immediately switches to the triangle with ! and the little green droid. then when I hit menu button it goes back to recovery screen..at the bottom there it says this exactly:
#manual mode#
--Install from sdcard...
Finding update package...
Opening update package...
Verifying update package...
E: failed to verify whole-file signature
E: signature verification failed
Installation aborted.
#manual mode#
if what braydon is trying works then we are in the money,,,if it doesnt then you may need a PC......but for now, are you using tiger or leopard?
I appreciate you patience....are you pretty sure I will eventually get my phone back to at least what it was?
im sure its just all about the tools we have,,,i mean in the end im sure you have a work pc or a friend with a pc or even a family member
can I at least get my contacts back right now or no?
did you have them backed up to backup assistant or your gmail account, or exported to your sd card?,,,,try logging onto your gmail account from your computer and check the contacts section,alot of time people dont realize that it syncs
Reactions: Hollaback72
Status
hlgqatar
