monkeydeus
- Feb 1, 2011
- 11
- 0
- 0
I've read the entire thread. I have honeycomb running on my NC fine.
I don't have a clue how to install the market.
Do I install the two downloads on my NC or my PC?
Do I connect my NC to PC?
Can someone dumb down the instructions step by step?
It can't really be dumbed-down any further, if this doesn't work for you, you might have issues with the way one of the components is set up.
You will download 2 files to your PC. Unzip them, and place the two .apk files in the same folder that contains the adb.exe file. THis is so when you run the adb command window, it knows where to get the files that it will push to your nook device.
Once you have found this folder and copied the files to it, make sure your nook is connected. I can't recall the link, but if you have issues, there is a set of drivers out there for recognizing the h.c. nook.
Assuming you have it connected correctly, open a command window by holding shift and right-clicking to get the "open command prompt from here" option in the context menu. Click that link, then type the commands exactly as shown. This should push the two files you need for the marketplace onto your nook, and you will be all set. Note that there are real stability problems with apps on h.c. right now. HTH
