HEY-
do you guys know any good applications to send chats/texts to phone numbers?
Roberto,
Thanks for the suggestion. I tried it - following step 4 of the Marketplace portion of post #1, in Terminal, I moved to the platform-tools directory, copied and pasted the first line (adb shell mount, etc.), hit enter, and got this message: "-bash: adb: command not found" Don't know what to do now. Any thoughts? Thanks again for your help and patience.
Actually that's an easy one....
Unless that folder is in your $PATH environment, you need to preface the command with ./ (./adb ...) if adb is in your current directory or give the full path to the directory. When in the Mac OS X command line environment, you are subject to the peculiarities (and power) of Unix.![]()
I feel like an idiot, but as long as you're OK helping, I'll keep asking. I started with ./ so the command line was "./adb shell mount, etc." I hit enter and got "error: device not found". Any thoughts?
Thanks again.
Now you asked one I probably can't answer.
I would check the obvious things, NC connected to computer via USB, SD card inserted, NC turned on and awake, etc.
ok so i got honeycomb going no problem. Now on to installing the market, got SDK installed and USB drivers install. when i go to CMD and type in abd devices i get abd is not recognized as internal or external command. what am i doing wrong? would love to get the market installed and get this thing going.
and when you go to device manager is your nook listed as the ADB something something?
If so, try to plug it into a different usb
or try to open the command prompt from the platform-tools folder (or wherever adb.exe is installed) by holding shift and right click on the folder
DKATZ- do you belong to SuFu too?
also
how you get google voice? i can't seem to install it....
I'm not sure what happened, but I have rooted B&N 1.1.0 (internal) and rooted HC (SD card) both working fine here. I installed the 1.1 update before doing anything else, but I don't see how that would affect HC. I also tried Froyo on a SD card, but wasn't that impressed.
I feel defeated. It's a terrible feeling.
Is there a way to load apps without installing the Vending.apk and GoogleServicesFramework.apk? I can't get any of my computers to let me access adb... I've tried Win7, XP and OS X.
Can someone please tell me if I should have Google map and Gmail apps installed after going through the adb market and framework install?
Thanks in advance.
Philn
I need to get up to 5 posts before I'm permitted to send a pm but I appreciate the quick response. Thanks. The only netbook I have at home right now is running jolicloud but I may take you up on the windows offer later in the week -- really hoping to solve this problem over the weekend though.
The nook shows up in "android phones" as "andfroid composite ABD interface". I tired "abd.exe" and "abd devices" from the prompt from the platform-tools folder and still get the error.
i am having the exact same issue. i also tried it on xp and am getting the same error. i downloaded the usb drivers and did everything else everyone has suggested. im wondering if it is because i used my blackberry as my card reader? im almost officially giving up and going to try to install it on the internal memory.
