HOW TO FIX-fastboot mode started udc_start()
Also after installing the fix you can use the phone but mine is a p505r and when it goes to screen blanker afte r30 sec. it locks up---I end up pulling the battery to reboot it. So I set the balnker to 30 min also no good ...but a Hell of a lot better. As soon as I figure how to get it into restore mode I should be OK.. Like the above messaga said a new rom would be great...
Thanks for looking...
I found a newer and seem better basic rom please check this one out. I loaded it no problem very smooth no errors.
I cant mine out of emergency mode either! i tricked software to think im from singapore and downloaded p500 driver and it recognized device. then disabled lg modem driver and restarted computer. the KDZ updater sees phone but i get the same error the guys above did. wat else can i do? has anyone fixed this???
I've followed every step to the T and I still can't this thing out of Emergency Mode. I also keep getting errors with Kbz. With the V10E its the Upgrade Error, WParamv:100 LParam:4008. Frustrated!
Im stuck here, did you ever fix this???
Ok so i found the quality one p509 drivers and installed them. but im still getting the same error
This is what is in the log files i got when trying to unbrick
[16:33:09:420] : =============================================
[16:33:09:420] : Log is started on 24.01.2012, at 16:33:09:420,
executable: C:\Users\Sexy Babe\Downloads\KDZ_FW_UPD_EN\KDZ_FW_UPD.exe (ProcID: 0x00000f5c),
compile time : Dec 3 2010 21:03:18
[16:33:09:420] : Version :
[16:33:09:422] : Get Usb Port
[16:33:09:426] : rsi.strFriendlyName=LGE Android Platform USB Serial Port (COM7)
[16:33:09:426] : FriendlyNameList[iii].szFriendlyName=LGE Android Platform USB Serial Port
[16:33:09:426] : WM_COPYDATA ?޽??? ???? 1 - COM7
[16:33:09:426] : Port = COM7
[16:33:09:429] : UNKNOWN : Req(12) -> Rsp(13)
[16:33:09:430] : UNKNOWN : Req(12) -> Rsp(13)
[16:33:09:431] : UNKNOWN : Req(12) -> Rsp(13)
[16:33:09:431] : >> DIAG_STATUS_F FAILED
[16:33:09:436] : >>Get Model Name [DIAG_VERNO_F]
[16:33:09:437] : BAD CONN MODE : Req(0) -> Rsp(3)
[16:33:09:438] : BAD CONN MODE : Req(0) -> Rsp(3)
[16:33:09:439] : BAD CONN MODE : Req(0) -> Rsp(3)
[16:33:09:440] : BAD CONN MODE : Req(0) -> Rsp(3)
[16:33:09:441] : BAD CONN MODE : Req(0) -> Rsp(3)
[16:33:09:442] : BAD CONN MODE : Req(0) -> Rsp(3)
[16:33:09:442] : FAIL (No Phone)
[16:33:09:442] : GetModelName() Operation Failed Check Diag CMD
[16:33:09:442] : EMERGENCY Booting Mode
[16:33:09:442] : >>Get Model Name in Emergency Mode [DLOAD_VERREQ_F]
[16:33:09:443] : BS/P506/7DEXYBA~1\AppData\Local\Temp\DZ
[16:33:09:443] : WM_COPYDATA ?޽??? ???? 0 - P506
[16:33:09:454] : DLOAD_NAK_F reason_msb = 3, reason_lsb = 3
[16:33:09:454] : [ DLOAD ERROR ] : NAK_INVALID_LEN
[16:33:09:455] : DLOAD_NAK_F reason_msb = 3, reason_lsb = 3
[16:33:09:455] : [ DLOAD ERROR ] : NAK_INVALID_LEN
[16:33:09:456] : DLOAD_NAK_F reason_msb = 3, reason_lsb = 3
[16:33:09:456] : [ DLOAD ERROR ] : NAK_INVALID_LEN
[16:33:09:456] : NV Write Fail : NV ITEM 9028(9028)
[16:33:09:556] : >> GET DLOAD COMM MODE
[16:33:09:557] : [GetCommMode] Communication mode : 2
[16:33:09:557] : Pre Nand Download
[16:33:09:557] : >>Set Trusted Mode [DLOAD_NAND_SEC_MODE] sec_mode = 1 (1=trusted 0=NonTrusted)
[16:33:09:557] : WM_COPYDATA ?޽??? ???? 3 - TRUSTED MODE
[16:33:09:568] : [COM7] >>NandFlashInitWithFile(PARTITION TBL)
[16:33:09:568] : WM_COPYDATA ?޽??? ???? 3 - INIT PARTITION TBL
[16:33:09:660] : ?޽??? ???? TYPE_WPARAM_WRITE_TO_SDRAM 3
[16:33:09:660] : [COM14] ?޽??? ???? TYPE_WPARAM_WRITE_AMSS 15
[16:33:09:660] : [COM7] >>NandFlashInitWithFile(AMSS MODEM HEADER)
[16:33:09:664] : WM_COPYDATA ?޽??? ???? 3 - INIT AMSS MODEM HEADER
[16:33:09:675] : [COM14] >>Dl_AsyncWrite()
[16:33:09:675] : >> AMSS FLASHING ...
[16:33:09:679] : ?޽??? ???? ProgreassiveBar Init wParam TYPE_WPARAM_PROGRESSIVE_POS=5 lParam(pos)=0 nResult=0
[16:33:09:679] : Sending Pkt Seq : 0
[16:33:09:680] : Sending Pkt Seq : 1
[16:33:09:680] : Sending Pkt Seq : 2
[16:33:09:680] : Sending Pkt Seq : 3
[16:33:09:680] : Sending Pkt Seq : 4
[16:33:09:680] : Sending Pkt Seq : 5
[16:33:09:680] : Sending Pkt Seq : 6
[16:33:09:680] : Sending Pkt Seq : 7
[16:33:09:681] : Sending Pkt Seq : 8
[16:33:09:681] : Sending Pkt Seq : 9
[16:33:09:692] : Dl_AsyncWrite - ErrNo(45), Addr(0x00004800), NandErrNo(0x04)
[16:33:09:692] : [COM14] ERROR Dl_AsyncWrite() TYPE_LPARAM_UPGRADE_ERROR_WRITE_TO_FLASH
[16:33:09:692] : WM_COPYDATA ?޽??? ???? 3 - Close Port
[16:33:09:692] : Close Port<<
[16:33:09:692] : TYPE_WPARAM_UPGRADE_ERROR
[16:33:09:692] : ?޽??? ???? - TYPE_WPARAM_UPGRADE_ERROR Error Code = 4008
[16:33:09:749] : Log finished
OK every thing is good I bricked it tried to load a rom from the card and now it won't even light up LOL
So I guess i need a big roll of phone wire...
Nice phone when it worked
Well unless anyone of you fellows got a idea how to unbrick it I guess a hell of a deal on Ebay.
Damn now I need a geekphone
haha, thats funny, my thrive wont turn on either now, now i hav to get a nexus one, which may be a little outdated but its better than a bricked thrive
Yea i got the same code 4008 , i think we used the wrong box , shoulda been emergency not diag
Hold on they all can be fixed by jtag (YOU KNOW THAT RIGHT):). The Jtag costs about the same as your phone but will do all these phones...One of us should buy one LOL...I just sent a email to a guy in Red Deer Alberta that offers the service for phones and xbox and all that good stuff..Ill let you know. Im very much wanting to put the stripped new release on my LG P505 ..Of coruse he can unlock it same time...
WAIT 4 IT........
;)L will be bacck
Also in my browsing for help I noticed the samsung has problems bootin into download or emergency mode so folks cut up a spare usb cable twisted some 100k resestors to getter and short out 2 pins on the cable. And bang downlosd mode pops up........Wonder if that would work 4 any other cell phone (He said whilsy scratchin head):confused:
I dont get how u guys brick ur phones? If it doesnt turn on and u dont have CMW install then u just flash p500 stock kdz if not use fastboot
I think they are trying to flash to a P506 rather than dealing with the P500 long enough to get it rooted and get CWM installed.
Jon OapostraphyBrien
