How to Fix: Unfortunately, the process android.process.media has stopped
Thx to Cindy Delgallo. She posted a fix on the Gal S3.
Here is what worked for my Gal S4:
1> Clk on lower left button, select "SETTINGS".
2> Clk on upper right "MORE".
3> Clk on "App Mgr".
4> Clk on lower left button for menu.
5> Clk on "RESET APP PREFERENCES"
My error message "Android.Process.Acore" dissapeared !!!
What a struggle this pain has been...It was nearly time for the HAMMER.
Yea, Thx again, Cindy, for steering me towards the fix.
My Samsung Galaxy S4 is flashed & the process android.process.acore has stopped & I seen that u can reset apps in my general settings can I do that if my phone is flashed without losing my telephone number again?
Yes, Carri... Everything fine. All my bookmarks, phone numbers, eMails, text, contacts, all unaffected.
Hello.. If anyone has this problem cos i just had , go into Settings ...App Manager...All...Media storage..and Disable that's it for me no more popping up see how it goes on later . Have a nice day !!
Have recently been having this popup, but I have tried all solutions listed in this thread. I haven't seen anymore popups (yet).... I hope it fixed it.
Cindy,
Yours was the only suggestion that worked., This error message started this afternoon and I spent 2 hours trying everything. I don't know where you are but if you ever get to the UK there's a drink waiting for you
I have a note 3. This is my second go around with this. This time it is messenger .Cindy, at least your remedy worked the best. Now hopefully it helps the second time. thanks again.
I set about following student6000 with the instructions but did not mention that you. >swipe the screen left> after you go into application manager this will give you the option to select. all>
Hope this helps dummies like me:p
I'm on a tablet 4.4... after a few hours reading foruns etc... and doing everything written clear data/ caches, disabling apps etc...
The solution was to just go into settings/ date and time, disable automatic time and date (via network or gps)... totally disable ...
that's it!
Everything else is on and working
Hi this is moin.
is solved you have to boot your phone in recovery and choose wipe cache partition and now reboot your mobile it will solved.
thank u this worked ive been stressing since last night!u rock :):):) this is how its fixed....1. Went to settings
2.Application Manager
3.ALL
4.Clicked the BOTTOM LEFT button on the phone itself
5.RESET APP PREFERENCES
Fixed
I see a couple solutions but all mean backing up and losing your data I cant afford to do that
THANK YOU THIS WORKED FOR ME MY GALAXYS4Thx to Cindy Delgallo. She posted a fix on the Gal S3.
The problem is to get from the error message to the password to get into anything, plenty trial and error.
Then it was all plain sailing Cindy get an extra 10 stars how did you find it ??
NO NO NO DO THIS, Thx to Cindy Delgallo. She posted a fix on the Gal S3.
hi
i get this error triggered this time by the paypal app
/did factory reset then it also was viber / skype
its unstappable on my android 5.0 v20f LG G3.
all troubleshooting steps dont work
phone dailing function / sending email with outlook app instantly crashed + every 20 seconds the message appears
horrible
do you know what big <<edited by mod>> this is ???!!!!
kctraci1
