[How-to] Guide to Rooting with software version LS670ZVC
Status
Not open for further replies.
So I started the original process and used the kp500 utility found here http://forum.androidcentral.com/lg-...-software-version-ls670zvc-24.html#post601470 . I cannot get the original root to take now so not sure what is going on. Here is waht I got right after the v9 restore
C:\android\adb>adb push rageagainstthecage-arm5.bin /data/local/tmp/rageagainstt
hecage
438 KB/s (5392 bytes in 0.012s)
C:\android\adb>adb push su /data/local/tmp/
483 KB/s (26264 bytes in 0.053s)
C:\android\adb>adb push busybox /data/local/tmp/
1953 KB/s (1926944 bytes in 0.963s)
C:\android\adb>adb shell
$ chmod 4755 /data/local/tmp/rageagainstthecage
$ chmod 4755 /data/local/tmp/busybox
$ cd /data/local/tmp
cd /data/local/tmp
$ ./rageagainstthecage
[*] CVE-2010-EASY Android local root exploit (C) 2010 by 743C
[*] checking NPROC limit ...
[+] RLIMIT_NPROC={3374, 3374}
[*] Searching for adb ...
[+] Found adb as PID 78
[*] Spawning children. Dont type anything and wait for reset!
[*] If you like what we are doing you can send us PayPal money to
[*] 7-4-3-C@web.de so we can compensate time, effort and HW costs.
[*] If you are a company and feel like you profit from our work,
[*] we also accept donations > 1000 USD!
[*] adb connection will be reset. restart adb server on desktop and re-login.
$ exit
exit
It can take anywhere from 1-20+ tries. Sometimes rebooting PC and phone helps.
The rage exploit depends on a race condition. It doesn't always hit gold.
If you want, try z4root from within android. It is often quicker at getting root (BTW it'll work in V9 but not VC)
did checksum all good but still get this
01:40:35 : [C:\LGMobileUpgrade] ???丮 ???? ?õ?
01:40:35 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
01:40:35 : Start Date : 2011-02-16 01:40:35
01:40:35 : -------- Buyer Test mode ---------
01:40:35 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ?
01:40:35 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
01:40:35 : *****CheckOS Start********
01:40:35 : Microsoft_Windows_Vista Professional_
01:40:35 : *****CheckPCSyncPrograms Start*****
01:40:35 : PCSyncPrograms Not Found
01:40:35 : SetEmerModeAT()
01:40:35 : _IsConnectedPhone Call
01:40:41 : _IsConnectedPhone(1)
01:40:41 : 0 - NotConnected.
01:40:41 : 1 - Normal connect success
01:40:41 : 2 - Emergency connect success
01:40:46 : Checking the connection with the cell phone...
01:40:46 : dwWaitResetTime(40000 ms)
01:40:47 : Phone Mode(1)
01:40:47 : *****GetPhoneType Start*****
01:40:50 : Phone Type : CDMA
01:40:50 : *****Start GetPreviousStep*****
01:40:50 : _GetPreviousStep(dwStep:0xffff)
01:40:50 : _SetPhoneNumber retval=1
01:40:50 : *****GetPhoneModel Start*****
01:40:52 : *****GetPhoneBinaryVersion Start*****
01:40:52 : Phone Bin Version : LS670ZVC_11
01:40:52 : *****Get ESN / IMEI / MEID Start*****
01:40:54 : ESN/IMEI/MEID : A00000284EB007
01:40:54 : *****GetPhoneNumber Start*****
01:40:57 : Phone Number : A00000284EB007
01:40:57 : ???? ?˻? ?Ķ??Ÿ - ESN_IMEI : A00000284EB007, Model :
01:40:58 : *******CheckBinVersion***************
01:40:58 : New Bin Version(ls670zv9_20), Current Ver(LS670ZVC_11)
01:40:58 : ?ֽ? ?????̹Ƿ? ???׷??̵带 ?? ?ʿ䰡 ????.
01:41:00 : _GetAuthMark : wAuthMark(5413)
01:41:00 : Wait 3Sec
01:41:06 : _SetAuthMark Ok : wAuthMark(5413), PhoneMode(1)
01:41:06 : *****Start _GetBatteryLevel*****
01:41:08 : Battery(5)
01:41:10 : ResetPhone...
01:41:10 : Checking the connection with the cell phone...
01:41:10 : dwWaitResetTime(40000 ms)
01:41:40 : _IsConnectedPhone Call
01:41:45 : _IsConnectedPhone(1)
01:41:45 : 0 - NotConnected.
01:41:45 : 1 - Normal connect success
01:41:45 : 2 - Emergency connect success
01:41:45 : Phone Mode(1)
01:41:45 : m_dwBootWaitTime(35524)
01:41:45 : Checking the connection with the cell phone...
01:41:45 : dwWaitResetTime(30000 ms)
01:42:15 : _IsConnectedPhone Call
01:42:21 : _IsConnectedPhone(1)
01:42:21 : 0 - NotConnected.
01:42:21 : 1 - Normal connect success
01:42:21 : 2 - Emergency connect success
01:42:21 : Phone Mode(1)
01:42:21 : Call _ModeOffline()
01:42:22 : *****CheckPCSyncPrograms Start*****
01:42:23 : PCSyncPrograms Not Found
01:42:24 : CLGMobileHttp Class ?Ҹ????.
01:42:24 : CLGMobileHttp Class ?Ҹ?...
01:42:24 : ****************CheckAndDownload********************
01:42:24 : ******Extract Start ls670zv9*****
01:42:24 : Model Dll Dir(C:\ProgramData\LGMOBILEAX\Phone\)
01:42:24 : ExtractInfo Error(0)
01:42:24 : Extract cab file error.
01:42:24 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ?
01:42:24 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
01:42:24 : !pUpgrade->StartProcessing ... PostMsg STEP_TYPE_ENV_ERROR
01:42:24 : Page_Error ?κ??Դϴ?
01:42:24 : OnStepMsg STEP_TYPE_ENV_ERROR delete m_pLGCyonUpdate
im getting that also and i need it rooted so i can flash lego rom to get a gingerbread theme
Well, if you are truly getting the exact same error then it is because you typed the name of the cab file incorrectly.
The highlighted sections indicate that user typed
as the cab filename in KP500, when they should have typed
LS670ZV9.cab
My suggestion is you read over step (p) very carefully including the section that addresses the common cause of the Extract cab file error.
Also review step (i) which verifies the checksum of the cab file.
Hi, I got to the end of your instructions without any errors or problems, but when trying to install Xionia's Clockwork Custom Recovery and typing "adb shell" I get the "$" sign instead of the "#" sign. When I type "su" it says Permission denied. Does that mean I'm not rooted? Is there anyway to check if you're rooted and what should if I do if I'm still not rooted? When going through the instructions to get root I did get the "#" sign when I should have, so I thought that meant I did get root.
I was able to install Super User and Titanium Backup, so does that mean I have root? But when I tried the "mount -o remount,rw -t yaffs2 /dev/block/mtdblock5 /system" for the custom recovery it says permission denied.
Also I have VC which I updated through the LGUpdate Tool.
Thanks.
Before you type "su", turn on your phone, make sure you aren't on the screen saver. Type "su" in the adb shell, then look for a prompt on the screen of the phone asking you to allow root privileges. Acknowledge that prompt by allowing root privileges.
Reactions: cheezeit
same problem here
having a bit of a problem.
step six, when i try adb shell i get -exec '/system/bin/sh' failed: No such file or directory <2>
I am having the same problem, and I did step 4. I reverted back to stock, applied V8 to V9 update, used LG updater to update to VC about an hour ago, did steps 1-5 on this guide.
When you did step 4, what was the message you saw?
Finding update package...
Opening update package...
Verifying update package...
E:failed to open /sdcard/update.zip (No such file or directory)
E:signature verification failed
Installation aborted.
You did do step 4, but you missed the part about placing the update.zip on your sdcard prior to starting the instructions:
The V8_to_V9 update zip can be found here.
This file must be placed on the root of your sdcard PRIOR to doing anything outlined in this guide.
Reactions: jennvee
Oh, thank you so much, that makes sense! I thought it was there already since I did the V8 to V9 update, but I must have removed it. Downloading and sending it over now. Thanks for the quick reply!
What if the phone was not and is not rooted?
My brother also has an optimus but he is not very tech savvy so he has not rooted his phone. He saw CM7 and now wants that, but he updated via phone to VC. I know CM7 is compatible but do I need to revert back to V9 even though his phone has never been rooted? Or can I just root it as is?
If he updated to VC via Sprint's OTA update, then you need to revert.
If he updated to VC using the LG Software Updater tool, then you can root without doing anything extra.
Status
fidsomedia
