[How-to] Guide to Rooting with software version LS670ZVC
Status
Not open for further replies.
I've been trying unsuccessfully to revert to v9 and always get hung up at the same spot:
23:01:01 : [C:\LGMobileUpgrade] ???丮 ???? ?õ?
23:01:01 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
23:01:01 : Start Date : 2011-02-13 23:01:01
23:01:01 : -------- Buyer Test mode ---------
23:01:01 : [C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone] ???丮 ???? ?õ?
23:01:01 : RemoveDirectory1 Error(2):C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone
23:01:01 : *****CheckOS Start********
23:01:01 : Microsoft_Windows_XP_Home Edition_
23:01:01 : *****CheckPCSyncPrograms Start*****
23:01:02 : PCSyncPrograms Not Found
23:01:02 : SetEmerModeAT()
23:01:02 : _IsConnectedPhone Call
23:01:07 : _IsConnectedPhone(1)
23:01:07 : 0 - NotConnected.
23:01:07 : 1 - Normal connect success
23:01:07 : 2 - Emergency connect success
23:01:31 : Checking the connection with the cell phone...
23:01:31 : dwWaitResetTime(40000 ms)
23:01:32 : Phone Mode(1)
23:01:32 : *****GetPhoneType Start*****
23:01:40 : Phone Type : CDMA
23:01:40 : *****Start GetPreviousStep*****
23:01:40 : _GetPreviousStep(dwStep:0xffff)
23:01:40 : _SetPhoneNumber retval=1
23:01:40 : *****GetPhoneModel Start*****
23:01:42 : *****GetPhoneBinaryVersion Start*****
23:01:42 : Phone Bin Version : LS670ZVC_11
23:01:42 : *****Get ESN / IMEI / MEID Start*****
23:01:45 : ESN/IMEI/MEID : A00000288C24F5
23:01:45 : *****GetPhoneNumber Start*****
23:01:48 : Phone Number : A00000288C24F5
23:01:49 : ???? ?˻? ?Ķ??Ÿ - ESN_IMEI : A00000288C24F5, Model :
23:01:49 : *******CheckBinVersion***************
23:01:49 : New Bin Version(LS670ZV9_20), Current Ver(LS670ZVC_11)
23:01:49 : ?ֽ? ?????̹Ƿ? ???׷??̵带 ?? ?ʿ䰡 ????.
23:01:51 : _GetAuthMark : wAuthMark(20049)
23:01:51 : Wait 3Sec
23:01:57 : _SetAuthMark Ok : wAuthMark(20049), PhoneMode(1)
23:01:57 : *****Start _GetBatteryLevel*****
23:01:59 : Battery(5)
23:02:01 : ResetPhone...
23:02:01 : Checking the connection with the cell phone...
23:02:01 : dwWaitResetTime(40000 ms)
23:02:31 : _IsConnectedPhone Call
23:02:37 : _IsConnectedPhone(1)
23:02:37 : 0 - NotConnected.
23:02:37 : 1 - Normal connect success
23:02:37 : 2 - Emergency connect success
23:02:37 : Phone Mode(1)
23:02:37 : m_dwBootWaitTime(35749)
23:02:37 : Checking the connection with the cell phone...
23:02:37 : dwWaitResetTime(30000 ms)
23:03:07 : _IsConnectedPhone Call
23:03:12 : _IsConnectedPhone(1)
23:03:12 : 0 - NotConnected.
23:03:12 : 1 - Normal connect success
23:03:12 : 2 - Emergency connect success
23:03:12 : Phone Mode(1)
23:03:13 : Call _ModeOffline()
23:03:14 : *****CheckPCSyncPrograms Start*****
23:03:14 : PCSyncPrograms Not Found
23:03:15 : CLGMobileHttp Class ?Ҹ????.
23:03:15 : CLGMobileHttp Class ?Ҹ?..
after this the program crashes. The dos script says "This application has requested the Runtime to terminate it in an unusual way. Please contact the application's support team for more information." and I get a pop-up that says LG-Utils has stopped working....I have tried everything, suggestions???
Update of LG-Utils Application error report:
Problem signature:
Problem Event Name: APPCRASH
Application Name: KP500-Utils-EN.exe
Application Version: 0.4.2.0
Application Timestamp: 4a8ab16a
Fault Module Name: KP500-Utils-EN.exe
Fault Module Version: 0.4.2.0
Fault Module Timestamp: 4a8ab16a
Exception Code: 40000015
Exception Offset: 00020c4f
OS Version: 6.1.7600.2.0.0.256.48
Locale ID: 1033
Additional Information 1: e5b7
Additional Information 2: e5b7c8a4e3aaa7204f214450b489d608
Additional Information 3: 5175
Additional Information 4: 5175c098ae834f6c2b8eb1bd4a970ae0
I need some help. I played around with rooting my phone and installed the VC007 Rom and it ended up bricking my phone. But I was able to use the un-brick method to fix it.
I have the Drellisdee installed, but I think I've lost root access somewhere along the way. So I was going to try to root it again. When I get to the step to fire up the shell, it shows a #, but it says the system/bin/mount is not found.
If I download a root checker from the market, it says I'm not rooted. But it does say Busybox is installed
Please help
Does the LG Mobile Updater work by itself without invoking from KP500?
If not, I would try uninstalling that + the drivers, then reinstalling both.
If that doesn't work, I would try a different PC.
If you have #, then you have root, in the sense that you have root privileges to do more things. Whether you have root installed so that other programs can use it (which is what the root checker is checking), is related but different than having root so you can install stuff.
From one of my previous posts:
We use "root" in two slightly different senses.
You have "root" the login id (and associated permissions) designated by the "#" prompt in shell, let's call this root login. It is referring to a login status, not an ability, and thus is implicitly temporary. With "root" login id/permissions, you can always install the 2nd sense of root below.
The 2nd way we refer to root, is the "capability" of on-demand changing of login-id/permissions to root within Android and linux. Some people refer to this a permanent root. Rather than referring to the "login" id, we are referring to the capability of obtaining that login id whenever we want.
As I mentioned in your other post, your problem is not related to root. Either the path you entered for mount is typed in incorrectly or the partition containing /system/bin isn't mounted.
LG Mobile Updater and Support tool both work and say I have the most current version (ZVD) and don't need to update...
tried on 2 different computers, both windows 7 (one x86 and one x64) and get the same error. All drivers are installed correctly and don't show errors and phone shows up when plugged in...still at a loss:(
What is this DOS script referenced in the error. I don't remember running a DOS script to invoke KP500.
Off the top of my head, the only other thing I can think of is some form of permission problem. The KP500 front-end appears to be able to invoke the LG updater tool and the Updater tool appears to communicate with your phone.
I think he means the DOS prompt. Obviously there is no "script" (as in a batch script).
Finally got it to work. Just restarted the LG update software before running kp500 and ran on a windows 7 32 bit instead of 64...thanks!!
My phone is only a month old and it came installed with ZVC. So I followed the directions but can't get it to root. I have tried this 4 times with the same results. The first thing that goes wrong is that I can't run the chmod. rageagainstthecage does run, but the phone never reconnects. Here is the log:
david-grosss-mac-pro:tools davidgross$ ./adb reboot recovery
david-grosss-mac-pro:tools davidgross$ ./adb push rageagainstthecage-arm5.bin /sdcard/rageagainstthecage
1136 KB/s (5392 bytes in 0.004s)
david-grosss-mac-pro:tools davidgross$ ./adb push su /sdcard/su
4678 KB/s (26264 bytes in 0.005s)
david-grosss-mac-pro:tools davidgross$ ./adb push busybox /sdcard/busybox
6001 KB/s (1926944 bytes in 0.313s)
david-grosss-mac-pro:tools davidgross$ ./adb shell
$ cd /sdcard
$ /system/bin/chmod 777 /sdcard/rageagainstthecage
Unable to chmod /sdcard/rageagainstthecage: Operation not permitted
$ ./rageagainstthecage
[*] CVE-2010-EASY Android local root exploit (C) 2010 by 743C
[*] checking NPROC limit ...
[+] RLIMIT_NPROC={3372, 3372}
[*] Searching for adb ...
[+] Found adb as PID 62
[*] Spawning children. Dont type anything and wait for reset!
[*] If you like what we are doing you can send us PayPal money to
[*] 7-4-3-C@web.de so we can compensate time, effort and HW costs.
[*] If you are a company and feel like you profit from our work,
[*] we also accept donations > 1000 USD!
[*] adb connection will be reset. restart adb server on desktop and re-login.
$ david-grosss-mac-pro:tools davidgross$ ./adb shell
error: device not found
Rage won't work on the VC recovery. You need to revert to V9 first. See my signature.
$ cd /sdcard
Phone came with software version above ZV9 = You have the OTA update.
OTA update = You need to revert to V9 first.
EDIT: See the instructions in sfhub's signature (or the second link in mine).
OK I'll try that - I wasn't sure if that counted as the OTA update. Thanks a lot for the help guys.
No problem! My bad, actually. The guide didn't specifically give instructions that pertained to phones that came with ZVC or ZVD (mainly because I was lazy and figured people would assume preinstalled equals OTA - WRONG!) but it's updated now.
So in reality, thank you for falling prey to my assumptions :p
[warn]
this thread is now out of date so please look to the stickies for updated methods. Please refrain from posting as support is being discontinued​
[/warn]
Status
jesper76
