How To Guide Too Install Android 4.0.4 update.zip
Re: Manually install ICS direction
When I reboot into recovery I get clockwork. A while ago I used rom Manager to install CWM but never used it. Now I get put into CWM v5.8.3.1 but I cannot install the update. I keep getting errors I get
Error in /sdcard/update.zip
(status 7)
Instalation aborted.
I can however reboot my system with a battery pull. It will not reboot itself.
Anyway to get CWM removed off my phone? Do I have to do the unbrick and restore method
The update.zip in this thread is the Official OTA update, it will only work in stock recovery....If you don't wan't to have to unbrick, although i recommend it before flashing a new OS...i belive nigel has compiled an update.zip thats flashable through CWM, ill find the link and throw it back in here..
EDit: THe Delooper removes CWM i believe. install that zip through cwm, then the update.zip through stock recovery.
VenumX, your method worked and I now have ICS running!
Thank you again tommyjoesanders, this worked beautifully! I am approaching 50 years old, so I have some experience with old DOS commands.
I know some have mentioned the "cd" (change directory) DOS command and I am just suggesting the following edits to the instructions in the OP to include the info below (or some similar wording) to make it easier for folks to follow:
7. now you will get your c:\user\ whatever is your layout. at the C: prompt. type this command
"cd c:\adb" (without the quotation marks) and press enter
You can then eliminate steps 8 and 9, since the "cd" command will take you straight to C:\ADB>
It will actually take you straight there no matter what folder you started at.
Flashed to ZVD and I still can't get the recovery to work. I get a quick glance at Andy with a !. Update is named Update.zip not .zip.zip. Any ideas?
Just to clarify the update goes in the root folder right?
Alright thanks guys I'll flash tonight when my step dad gets here with his phone :p
Sent from my SPH-L710 using Tapatalk 2
It should be named update.zip all lowercase and not the root folder, just on you sd card not in a folder
Tapatalkin it from my Viper running ICS
the download file is already called update.zip . all you got too is transfer it too the sd card.
Please read the updated notes in the op. I hope this helps with any confusing anyone is having
Thx tommy, got our viper running ICS now, if I knew how I'd port some of it to xhdpi/,hdpi devices... compared to gb, LGS new skin is so beautiful.
PS - would you mind writing a guide for Linux to in case anyone uses the better os instead. :p... I would but don't want to cramp your style :)
my viper always reboot randomly and i want to flash with ICS.
when flashing in progress and then my viper reboot, will it make my phone bricked?
thanks guys
thanks again this method works really well. here are a few pointers..
after ics security error.. I went back to version vd using unbrick method, reenabled usb settings, regained root. installed voodoo..
rebooted to recovery, tried to reinstall ICS from sdcard that failed produced the google error 7..
I rebooted back to GB, the phone performed a system update. used to voodoo restore root,
rebooted back to recovery, then same update.zip installed ics completely.
Go ahead and write a linux install and just my download link in the guide so you don't have too spend alot of time setting the the thread up
Do I need to be rooted to use adb, and do I need a Windows machine or can I use a Mac?
*** never mind, found a YouTube video
Sent from my Viper 4G LTE on the "coming soon" network
New to this so please excuse myself. I downloaded the update.zip file and I'm continually getting a error during install stating that /patch is invalid i downloaded it numerous times and same result help!
Are you downloading it over your phones 3g connection. If so download it from WiFi or from a PC, you may be getting bad blocks since the file is 250+mb.
This is so frustrating... i can't even get into the c prompt because when i type C:\ on my laptop, it says that "C:\ is not recognized as a command"
oh well, i'll just wait till the push if someone can't tell me how to fix that. Sucks because it took forever to download the update file.
do you have teamviewer for windows? i will help you
try this ok
click on windows icon
type in cmd on search lines
then the another window will pop up it should say something like C:\Users\Owner>
at that point type cd\ and press enter
now you will see C:\>
type cd\adb hit enter
now it will show C:\ADB>
now type in adb reboot recovery and the phone will reboot in recovery at that point. make sure the update.zip is on the sd card or it will skip the recovery and reboot the phone
Trying now...
mike smith
