[How To][Links] ROMs/Themes and Kernels ~# Updated 3/20/11 #~
Status
Not open for further replies.
it wasn't even your post, i was just confused by the original xda one but thanks either way
edit: is there a mod for just the voice search long press fix? the power menu fix was freezing and soft-bricking my phone
I did find this:
""This fixes long press on the search button to launch Google Voice search.
This is based on the EB01 stock deodexed ROM. (This replaces /system/framework/android.policy.jar ... not sure if themes use this file.)
DISCLAMIER
Not responsible for your phone. Backup your phone.
/DISCLAIMER
Make sure that I500_BingSearchAndroid_11122010.apk is renamed or removed.
Install using CWM."" - Download
Sorry for the delay - I have been traveling.. back on a stable connection :)
I did find this:
thanks, i'll try it out and see how it goes
edit: it works out really well. going to regular search and voice search seems faster, like it made the button/phone more responsive.
is there someone that can help me i want a theme but these all seem to dark. i cant figure it out for my self and keep getting fc's..
I keep getting fc's too. The only theme I like that I've been able to flash without any problems is Touch of Blue.
I flashed jt1134's voodoo kernel and everything went fine. I was just wondering if there's a way to remove the android logo that overlays with the normal Samsung Galaxy S and Verizon boot animations?
You can try to flash another boot animation over the one on the phone/or remove the bootamination.zip fill all together..
Until we get the source code and kernels can be built to accommodate boot and shutdown animations we are having to piecemeal things together and sometimes they do not look so hot.
This is a dumb question, but I assume only EB01 themes go with EB01 ROMs? Seems almost everything is EB01 though. I just want to know what themes I can mix and match with what ROMs. :)
You are correct - EB01 ROMs and Themes need to be paired.
You can use a DL30 Theme with an EB01 ROM if you use the EB01 theme hack..
I have used it a couple of times with mixed results - SC 2.4 is rather picky about the themes that it plays with...
Reactions: packerbacker
I'm confused. I downloaded "EB01 Debloated/Deodexed Froyo Leak+root+Froyo Clockworkmod" but when I looked @ the first post it says the EB01 isn't deodexed. Will I be able to use any of those EB01 themes or patches?
There is a stock EB01 ROM available. It is what was leaked and Adrynalyne and the other indie developers got their hands on. Some people prefer the stock look and feel so Adrynalyne made it available here:
http://forum.androidcentral.com/ver...acks/59339-release-eb01-rom-kernel-radio.html
and here in the first DroidXcon ODIN package listed:
http://forum.androidcentral.com/ver...roms-w-root-new-clockwork-updated-2-15-a.html
THAT ONE, AND ONLY THAT ONE (STOCK) is odexed. EB01 debloated/deodexed is not odexed hence the deodexed part of the name. All of Adrynalyne's superclean versions are deodexed. So you can safely use any of the EB01 themes with the EB01 debloated/deodexed rom and any of the EB01 superclean roms, just not the EB01 STOCK ROM.
True, it's not so bad. It just looks really funny, I'll just wait till Samsung releases the source code. It's not like my phone is booting up constantly that I see it anyway
I have rebooted my phone 5 times today - flashing new stuff and restoring old - that is first reboot in 6 days.
I agree.. forgot I had a boot animation.
Im going to sleep now, but i wanted to say you did an outstanding job with this thread, keep up the great work. and thank you
Reactions: JaeKar99
I'm still running dl30 rom... can I flash the eb01 gingerbread theme onto it?
Sent from my SCH-I500 using Tapatalk
The framework is different between the two. So the easy answer is 'no'... There is a DL30 Gingerbread located -> here - download links are still active.
It may not have the exact same look but still has many of the same theme features.
Hope this helps.
Status
ahsokacat
