[How To][Links] ROMs/Themes and Kernels ~# Updated 3/20/11 #~
Status
Not open for further replies.
I may not be of any help... But here it goes: The old (green) CWM does not mount memory properly and when you flash though it will scramble the phone and it does not function properly. When we (many of us) started flashing 2.2 ROMs this made the problem worse.
jt1134 reworked the CWM and posted the corrections here..
If you are using any 2.2 ROM on your fascinate - you will need to use this version (red)..
thank you very much for ur assistance ..is it best to flash that in odin? or can i flash in recovery from sd card?
It is by your preference. I flashed the zip in recovery and keep a copy on my sdcard.
I know that people have more comfort with Odin and that works just as well. Just ensure that you follow the instructions in the post.
I'm having a small problem with the super dark v3 theme and I wonder if anyone else is too.
The 3g icon at the top is constantly showing im sending/receiving data when task manager shows nothing is running and I have sync/background data off. It also changes in size every once in a while when it's looking for a signal.
Anyone else?
EDIT: running sc 2.6
Sent from my SCH-I500 using Tapatalk
this list is awesome! i've been looking for general instructions on flashing a theme. am i correct, in that you flash themes from red recovery by installing zip from sd card? also is it recommended to wipe cache & wipe dalvik cache?
Yes, you are correct... on all accounts.
Reactions: rion_j
I love super dark theme by thatdudebutch but love it even more with the colored icons, dialer, settings, themed market that nitroglycerine33 provided in his version. Thank you for fantastic work!
I tried 2 flash a themed market w no luck and was wondering if I would be able 2 apply it using metamorph instead of moving the vending file to system/apps w root explorer??
Which market did you try to flash? I just put up a link to one by nitroglycerine33 - that should work with SC 2.6.
just want to thank nitroglycerine33 for the kick ass job you have done and are still doing on the NITRO DARK its sick as hell man! very pleased!!
Lovin nitro dark theme more n more as I.use it love the.combo of dark + some color... Added in butchs swype metamorph from superdark n now the theme is perfect!!!
Also is nitro 1.1 for the 2.7 full rom that was pulled or the patch thats up now or can it wrk on both
Working great for me on the full ROM. Patch should only argument the 2.6 ROM... I don't see it compromising anything.
hey everyone im having a problem i have the...Super Clean version 2.6 - EB01/EB16 Froyo leak root+Froyo Clockworkmod w/Nonvoodoo eb16 kernel w/ dummy tether module...with the Midnight/Steel Blue V1.2SE. and today i just tried to go to my contacts and it force closes every time and i dont see contacts in the app drawer has anyone else had this problem or know why its happening
Be careful when you attempt to restore a backup you may enter a boot loop. I had this exact problem and could not restore a back up.
I had to reflash the base ROM.
I would recommend that you ensure you have a copy of 2.6, and the kernel on your sdcard.
Boot into recovery, clear cache partition, Dalvik cache and then reflash the 2.6 ROM then the kernel. That should get you back to where you were prior to the theme flash.
I have been hesitant to return to that theme on that ROM due to that event happening again.
Reactions: floater#AC
Status
stopwatch
