Re: [How-To] Rooting LS670ZVH
If you are running VC or VD recovery, rage will never give you root and will just lead to frustration because it will disable your ability to connect using adb, forcing you to reboot the phone.
Are you sure you are running the V9 stock recovery and you are running rage while booted into recovery? I believe in later recoveries they may have disabled running files directly from sdcard.ok so ive tried to root zvh for about a day and a half now, and no method seems to work. ive gotten rage to run but only from me putting it in a /data/local/tmp/000root folder and chmodding (chmod 777 /data/local/tmp/000root/*) cause it always says permission denied when i try to run rage from 000root in the sdcard....
