How To Manually Install Android 4.2.1 update.zip Using ADB Sideload
Got you covered. check your pm . I gave you what you needed
Hi tommyjoesanders,
I have the same dilemma. The 4.2.1 update fails to apply. The error is "assert failed: apply_patch_check("EMMC:/dev/block/platform/omap/omap_hsmmc.0/by-name/radio:10748160...". Based on your feedback in this forum, I understand this is an issue with the radio version on my phone. I have the FC12 radios and apparently need to flash the FH05 radios before applying the 4.2.1 update. Can you explain how to do it?
Hi tommyjoesanders,
I figured it out. Sprint's OTA 4.2.1 update would not install, because it requires the FH05 radios. My Galaxy Nexus had the FC12 radios installed.
This is what I did to correct the problem.
(1) Downloaded the FH05 radio files from toroplus_full_radios-FH05.zip
http://www.shabbypenguin.com/OUDstu...plus/Stock/FH05/toroplus_full_radios-FH05.zip
(Or, get the individual FH05 LTE and CDMA radio files from
xda-developers - View Single Post - [ACS] Return to stock using Odin)
(2) Extracted radio-cdma-FH05.img and radio-LTE-FH05.img from the zip file to my PC.
(3) Rebooted my Galaxy Nexus into fastboot mode by hold down the power, volume up, and volume down buttons.
(4) Connected my Galaxy Nexus to my PC using a USB cable.
(5) From my PC, I ran these android-sdk platform tool commands to flash the FH05 radios:
fastboot flash radio radio-LTE-FH05.img
fastboot flash radio-cdma radio-cdma-FH05.img
fastboot reboot
After the above steps, Sprint's OTA 4.2.1 update installed.
Thanks for the great tip! I had been all over looking to fix this and had updated from FC12 to FD02, but still failed up update the OTA. This is the only place I found the tip on FH radios. Flashed the .zip and now sideloading the OTA.
hi there i've got a samsung galaxy s3 i9300 and one day the battery died and after leaving it to charge and then trying to power it , it was stock on the samsung s3 screen after watching and reading several methods i've come to using the odin i downloaded a firmware named jelly bean 4.1.1 and the phone did the same thing after i followed all the instructions then i tryed the new release jellybean 4.2 and i got it to pass that screen showing a red and white screen thing but then its stock on the samsung screen where it just marked samsung and blinking with a blue on the led, after doing some more research i came to the stock firmware which is what it came with and this one now its passes the samsung galaxy s3 screen and the animation with the blue circle thing comes up like there original just bought s3 but then the samsung sign comes up stays like ten seconds then the blue circle start up animation does its thing again and it goes back to samsung and it does that and don't pass there please help me please
help!! im trying to side load ANY thing i can to get my droup up and running but every time i side load i get an error of signiture verification failed. What software do i need to load into my sprint s4. i think i wipe out the whole dang thing.
1/7/2014: just took my S4 back to best buy and told them the extream cold lastnight while i was working out side messed up the software. gont a brand new S4.
mersy78
