[How-To] Rooting LS670ZVD with GingerBreak (no reverting and OTA works too!)
Generally you get those errors because you didn't do a clean reboot before running gingerbreak. Pull your battery and try again.
"Thanks" posts aren't against the rules and they aren't spam as they're still technically on topic. Thanks posts are a good means of giving recognition but pressing the thanks button is more efficient IMO.
I actually just figured out the fix for the "sndmsg failed?" message. When I was getting that, I noticed my phone was giving me the "SD Card Ready to Remove" message. So, while it was still connected to the PC, and while I was getting the constant "sndmsg failed" alerts, I took out the sd card, waited a few seconds then reinserted it. A couple seconds later, I got the successful root message!
So, after days of trying to root my phone so I could tether it to my Nook Color, I finally got it rooted! Maybe this will help the other person that was having the same problem.
So "THANKS!" for the guide to rooting! And I know that the "Thanks" messages aren't against the rules, it just makes it harder to find the useful posts to troubleshoot. But thanks to everyone who put this guide together.
im trying this but u keep getting the messege: [-] sendmsg() failed? over and over again. after [+] Calculated idx: -1996 is this right?
Microsoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Langlois>C:\car
'C:\car' is not recognized as an internal or external command,
operable program or batch file.
C:\Users\Langlois>cd c:\car
c:\car>adb shell
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
error: device not found
c:\car>adb shell
$ rm -r /data/local/tmp
$ mkdir /data/local/tmp
$ exit
exit
c:\car>adb push gingerbreak /data/local/tmp/gingerbreak
176 KB/s (16830 bytes in 0.093s)
c:\car>adb push su /data/local/tmp/su
1282 KB/s (26264 bytes in 0.020s)
c:\car>adb push busybox /data/local/tmp/busybox
1426 KB/s (1926944 bytes in 1.319s)
c:\car>adb push Superuser.apk /data/local/tmp/Superuser.apk
1516 KB/s (94728 bytes in 0.061s)
c:\car>adb shell
$ cd /data/local/tmp
cd /data/local/tmp
$ chmod 777 /data/local/tmp/*
$ ./gingerbreak
./gingerbreak
[**] Gingerbreak/Honeybomb -- android 2.[2,3], 3.0 softbreak
[**] (C) 2010-2011 The Android Exploid Crew. All rights reserved.
[**] Kudos to jenzi, the #brownpants-party, the Open Source folks,
[**] Zynamics for ARM skills and Onkel Budi
[**] donate to 7-4-3-C@web.de if you like
[**] Exploit may take a while!
[+] Detected Froyo!
[+] Found system: 0xafd14129 strcmp: 0xafd1cb9d
[+] Found PT_DYNAMIC of size 264 (33 entries)
[+] Found GOT: 0x000142a8
[+] Using device /devices/platform/goldfish_mmc.0
[*] vold: 0066 GOT start: 0x000142a8 GOT end: 0x000142e8
[*] vold: 0066 idx: -3072 fault addr: 0x000131d8
[+] fault address in range (0x000131d8,idx=-3072)
What am i doing wrong?
I successfully rooted my phone however I am unable to flash or get xionia running i have the optimus s ls670zvd when i go into recovery it is still in my factory setting I followed the instructions word for word what am I missing
trying but I am getting an error I set the first commands to set temp write access to the data/local/tmp
but still can not do an adb push
I am gonna try again
didnt have these issues with the hero this optimus is a little confusing in comparison
were am i going wrong i get to mount -o remount,rw -t yaffs2 /system /system and them i think i essed somthing up cause it says blocked device and i have no clue what that means
" abd: permition denied "
my path is correct and adb shell work, i try to chmod 777 to data/local/tmp/ but still same error, may help me?
anyway to copy and paste it for use or give us a screen shot
and you are using adb correct? not abd?
yeah i went through the post and saw it took out battery and tried again worked. Thanks I flashed the Reborn ROM and am loving it....
At step 8 how long is a while this is what i keep getting
[*] vold: 2754 idx: -0001957
[*] vold: 2830 idx: -0001956
[*] vold: 2854 idx: -0001955
Still running but has been running for 30 min
Hit me up and ill help you out another way
Hi, So I'm not sure but something seems to be missing.. I've very hard to figure out how to do this but on windows 7 in the cmd line, after navigating to the specified location and meticulously ensuring that I'd followed every step perfectly prior to the following, I still, upon entering "abd shell" receive a message from cmd saying that "abd" is not a recognized internal or external command... can you please explain to me why that's happening...
Again, the path to the abd.exe file is perfectly set in the location specified by the video tutorial. It's not that. The zip file actually comes with abd.exe in it now so it shouldn't even matter..
What am I missing? I've tried to figure it out on my own for over 30 minutes so I don't feel bad about asking for help now...
edit**
oh my god im a dumb a** i knew i was missing something stupid... i was typing abd instead of adb... shame... dyslexia.
Well 3 days of reading, 2 operating systems, finally rooted on a dual boot mac with windows. Take your time and it works like a charm! Much thanks guys!
Dave7
