Root explorer worked great but I can not find amazon under the apps. Any ideas where out could be?
I attached the correct Z4 root apk on the second post of this thread. Try that one.
Enraged medic you should just download the file on your phone once you get it there get a app the let's you see your files like astrology file manager and go to where you put the file it should say apk file then click that and hit package installer click ok to install you might not have went to your settings app manager and click install unknown apps it might be good to do that before anything once that's all done you need to get the titanium back up once in there you could long press the app or click it and choose either freeze or delete you might not know what apps to not delete so read the post on what you can and can't and you should be good if the file problem persists then change the file look a Googleing download z4root apk and file the actual apk file not exe or anything else it should only say apk then transfer the file to you phone pc or just download from your browser hope that helps
Sent from my PC36100 using Tapatalk
With titanium it says that they are deleted but when it reboots they are back everytime. When I use root explorer amazon is nowhere to be found and gtalk says its deleting but also comes back everytime after reboot. I think I am doing it right because I was able to delete all the other programs I wanted to. Just not those two
Can you just use Root Explorer instead of z4Root and Titanium, or is root explorer just a substitute for Titanium? Is it a better program to use instead of Titanium?
With a temporary root can you change your boot up imagine (the white evo 4g) or will it revert back to stock flash screen after its out of temp root? Also does any one have any ideal how this will affect OTA updates? Since I have an older mac I dont want to do anything that could affect OTA updates since that is my only way to get anything. I would think just removing bloat ware and not system files it should be ok, as it will probably just reinstall all the bloat ware, but I dont want to chance it.
thoughts?
