How to successfully uninstall/optout of Xapush ads??
I cleared temp files and cache, then uninstalled an app called Stock Market Tips by mobileBeez NG6. This immediately cleared the existing notification and I havn't had anymore yet.
Hope this helps.
I installed addon detector & found the culprit: text cutie, which I got for text posts to instagram but I can live without!
Thanks for the help.
Airpush detector seems to have woekedca treat. Thanks for the tip.
- - - Updated - - -
Called now lets see if it works.....I only want a phone.....not a expensive ad producing droid ,be different if I wanted or needed any of the junk they bother me with........
add ons detector work best for me
just as a note for most people, the apps most likely to have the air push built in are things like live wallpapers or themes for launchers because when you're looking for the culprit in your app drawer trying to find out which app is the sketchy 1 you can't see your live wallpapers or your themes so people are less likely to find out which 1 it is
Sahel
