How to Voodoo ***Updated 27 Mar 2011***KERNEL BUILT FROM SOURCE/SOUND/UNDERVOLTED
So, forgive me for asking... but what will voodoo color do? And do you need to do anything to activate it (like you had to do with the voodoo sound app?)
thanks!
thanks!
voodoo color only works at 100% brightness with auto brightness turned off. you will see a differance in video playback and on browser video.
Reactions: JOrtenzi
well i am flashing 327-2. the third kernal to flash today! when i flashed 327 it got stuck in the boot animation. i had to pull battery, boot into cwm, clear both caches, then it rebooted fine. well 327-2 just booted up now. my vlotage has been around 3.85, will there be any kernals that can go lower or will it be too slow. and will we see any overclocked kernal soon.
Reactions: cordoni
this kernel supports overclocking i believe. but dont do that!! there is no reason to overclock your phone!!!!! you will get very little performance increase and run the risk of a very real HARDWARE BRICK. thats right kidos, not the "gunnermike53 i put frogs i in my phone brick", but an actuall warranty voiding brick.
other kernels will be available in the future that give better undervolted options.
Don't be skeered :P
Yep it takes me to a log in for xda on my pc or on my phone. I guess it's time to register at xda
You can do that or give me a minute I'll give you a megaupload link for the file. Just have to upload it. Actually register at XDA, AND, I'll upload it.
I know this isn't a support thread for the Kernel... BUT Now when I take video I can't hear any audio when I play it back. Has anyone else had this problem... also if I miss a call the phone unlocks itself. Help is appreciated.
Ookay.. To think that I just got a taste of froyo 2 weeks ago and I'm going into Voodoo. I'm nervous and understandably have a couple questions to be safe. I'm currently running SC2.9.2 NV, with the Honeycomb 3.1.1 theme. Do I go ahead and download the 2.9.2 Voodoo .zip and this kernel to my sdcard, go into CWM, wipe data and cahes, flash the 2.9.2 ROM, flash the new kernel, enable lagfix and reboot? Any steps I'm missing? I'm a bit scared but pretty confident I'll fix any screwup. Thanks!
do boot up sounds work with this now?
I don't think so. Jaekar99 was working on that. Haven't seen any update.
Also to let everyone know, Adrynalyne just put the kernel in the OP of his superclean thread and he said nonvoodoo can use it, they just have to create a folder called disable_lagfix in their voodoo folder.
I just saw that... is that a different updated kernel than what JT has posted on xda? or is it the same one? (0327-2)
HourFromNow
