HTC Desire ROM
Yeah hopefully Jake/Boostd just got a copy of MOTO's source code for it so maybe it will speed the development up some
I thought that I read the autorom wasn't working do you guys know if that's true or if it's been fixed.
One request: When someone has this up and running, can you upload a YouTube video?
Btw, Bizz, what's your heat like for your chip with this ROM? Normal, or less than typical when running at 1 GHz?
I'm running 28c max 33c
Oh yeah I'm running 1g max 750 min under normal operations
Interesting - that is way less than the core temp for my normal 800 MHz OC. I usually run 32 min, 38 max, 40 under extremes.
Sounds like this beast runs cooler - good news.
I'm. Running the low voltage kernel but that also battery temp the kernel isn't compatible with CPU temp
It seems that it runs a lot cooler on wifi than using 3G. I struggle to hit 100F over wifi after streaming iheartradio, browsing, using phonemypc, etc over an extended period. I didn't have wifi access today and had to use 3G and I shot up to 110F rather quickly.
Yep she gets a little warm on WiFi which kernel are you guys using
mine is actually cooler on wifi but on par with other roms (bugless beast and CM) when connected to 3G. I'm using whatever kernel the original alpha rom came with.
Oh I'm using the lower voltage kernel I think may not be who knows but I've been trying out the different kernels to see what happens. Didn't try one due to not having the WiFi updated portion
Still working on the RIL. Apparently Jake, the guy working on it, borked his droid but they're still trying to get it done. No real ETA yet.
Yeah don't know how he broke it. But let's hope he can get another one he makes some great kernels. Oh yeah let's not forget about the ril
dumpsterrentals101
