I have an EVO ...
Not in the gmail app. its menu then compose. There will be a looks curve but it will be easy. The think the biggest factor is moving around the OS. The card interface and gestures is a special thing. :D
Thanks for the answer. WebOS really is a breeze to navigate. I understand there is an app on Android that somewhat simulates the Cards in WebOS.
can you list the pre-installed apps that came factory loaded, thanks.
can you list the pre-installed apps that came factory loaded, thanks again.
can you list the apps that are installed on evo from the factory, thanks again and again.
doc, can you list the apps that are pre-installed on the evo from the factory, thanks.
CALM DOWN dont scare him off. He has been answering everyones questions .
As a fellow Pre owner myself, how hard was the transition to Android? I went to play with the Incredible (To get a taste) and found myself trying to use the "gesture area", I am just too used to it.
pretty much the same thing. I don't think I'll be switching right now.
When you were taking pictures, any lag when you pressed the button and the picture was actually taken? I love the camera on the Pre but too much lag on the Hero.
Doc -
were you able to answer any of my questions?
1) Do your upcoming calendar appointments show up on the home screen like they do on the HD2? (its displayed under the time and weather).
2) Does the time that the alarm is set for show up on the home page as well, like it does on the HD2? (its displayed under the time and weather).
3) Have someone call you or text you while your phone is locked and dont answer - do you get an LED notification like on the HD2?
4) Can you password lock the phone like other Droids?
:D:D:D
lags for the autofocus but not too bad but that can be cut off. But the pics are sooooo much better with the auto focus on
Doc -
:D:D:D
1. IDK. I didn't see it there. You may want to search the other htc thread bcus i would be the same.
2. IDK
3. yes the green LED flashes.
4. I didn't check but I don't see why not. Its part of the OS.
i want to know what 3d games are out there for android. what gameloft games are available. cant find any info online for that stuff i herd nfs shift was coming and asphalt 5 was out but what else. android should lets us see there app catalog on the pc
24.7 FPS for the graphics test
Does this seem low to anyone else? My Hero gets 24 fps on neocore when running Fresh Toast 2b2 OC'd to 767 Mhz. I would assume snapdragon phones could destroy that score.
OP: can you run the linpack and BenchmarkPi apps and report the scores? Thanks.
Appreciate the answers.
So YouTube HQ works over 3g as well but takes longer yo load? How much longer compared to the 4g demo's Sprint has been showing at their events?
masonbiz5
