Infinity Watch Face
Please fix the stopwatch! The icon vibrates but the app won't open. I've installed and have already launched it with the default launcher. Lots of people are having this problem if you read the comments on the Samsung app store. Have you found a fix? Thanks!
I initially had a similar issue and eventually found the cause. Although it looks like a stopwatch, what it's actually trying to link to is the Samsung timer app. Once I had installed the timer the icon worked fine for starting it.
But which timer app, there's so many of them. I stopped trying. Can you post a picture of the timer you got to work.
Open the Samsung Gear Apps (in Gear Manager), in the Staff Picks tab scroll down near the bottom to the Gear Essentials group. Tap the See More button to view all the Samsung provided apps. One of these is the Timer that is needed.
Cheers! You're right. I downloaded the Samsung timer app and all is working perfectly. Thanks!
Hey guys, sorry about your frustrations with the apps! I am working on the next update that brings customizable icons to the watch face as well as other features (digital clock included)
Hey. Love the watch face. The weather icon for me only works if I've previously opened the weather app. If not when I click on it all it does is vibrate. Any way to fix that? . Thanks
Really late to the party on this app, but am downloading NOW
Sent not from just an oversized phone but my Samsung Galaxy Note 4
I noticed this morning it's the number 1 paid app on the Samsung Gear app store. I don't know if that's in sales, downloads or just they randomly chose it in its placing of their paid apps but it's number 1 right now.
For some apps, for a reason I am not aware of, the app won't open with a shortcut until it was opened once before... Once I finish adding the new features, I will take a look at this and try to figure out what's happening :)
The update is out.
Now to figure out how to change icons from the stock ones.
Lots of new features I was already able to make use of
Thanks for the update.
Looks like edit apps isn't there? Oh well, the update still is a nice step forward.
Hey guys,
The custom icons are taking more time to implement than expected, but we are doing our best to get them out quickly :)
The new update adds these functions:
- Change between analog, digital, or both clocks together
- Add lines so the analog clock is easier to see
- Click the battery icon to see battery stats (there is a minor bug with the battery status, but an update to fix it will be out as soon as possible, sorry about the inconvenience!)
- Change the background of the watch face to one of various colors, or make it transparent and put whatever wallpaper you want with it
- Turn the vibration when apps are clicked on/off
To access the settings screen, click on the clock icon
I'd love to hear your feedback and put in other features you guys want :) The custom icons will be released soon.
Like us on Facebook for more updates and info:
http://fb.me/curlballCo
Cheers!
Thanks for making this watch face my favorite, very useful. Just a small suggestion. I think we should get rid of the "PM" or "AM" in the digital option since it's unnecessary. The way it's postioned above the time makes it looks uneven and squished.
All the apps seem to be working perfectly when pressed.
Yes, I also see the bug in the Battery Info.
I too can't wait to see when the app customization is released. Will it be also animated?
If the app customization does not include animation, can we replace the 4 small dots with real apps? That would of course mean the need to resize everything to make room. I don't mind paying extra for all the hard work you have put in.
Thanks again!
I find it annoying that when I swipe I always end up hitting an icon and launching something I didn't want. Plus it would be cool if it had the analog clock when Screen Always On is enabled. Am I doing something wrong or is there just not enough real estate on the screen to avoid that. Maybe a FIX for that would be to enable a double tap on an icon to launch it. That way a swipe wont trigger it.
bruce03510
