dusoccer10
- Jan 30, 2012
- 1,197
- 0
- 0
Re: [Instruction] How to Keep Unlimited Data on Verizon
Costco can do in-store transfer upgrades. Hypothetically, you could go to Costco and ask them to move your upgrade from Line 1 to Line 2. At that point, upgrade the Maxx to the Note 4 and let them activate it in store on Line 2. Once that is done, take the phone home as use Verizon online to move the Note 4 to Line 1 and reactivate the Maxx on Line 2.
If you want to order phones online, your best bet is to use either Verizon or Best Buy as they are the only two that allow upgrades to be transferred (which is the method you should use). If you want to do the "Best Buy Method", I do not recommend ordering online from Costco. There have been a few people who lost their unlimited because Costco has been known to randomly push through the plan change.
Hi is there anyway to keep udp and purchase a phone from costco...the are offering a 70 dollar rebate on the note 4. if so how would that work, this is my phone situation. If costco is not doable, what would you recommend
bought new nano sim at var had to call verizon to complete activation of sim
line1 htc dna with a nano sim installed udp upgrade available
line 2 moto droid maxx no sim tdp no upgrade available
thanks in advance
