Re: [Instruction] How to get a new phone and keep Unlimited Data on Verizon
This is from the old Slickdeals keep your unlimited data thread which is now closed. Anybody know if this method still works if I wanted to order the Galaxy Note 7....
My upgrade on one of my UDP lines is not till 2 months out yet, but as I go on to my Verizon and do a test purchase it will let me upgrade early and buy a subsidized Note 7... I have the 29.99 UDP. Want to stay on contract . I have 2 unlimited data lines where I could do the Sim swap, this method work for me 2 years ago.
Aohus Method (variation of the Flying Arrow Method)*
(for accounts with at least 2 UDP lines)
You can do Aohus if you have a line situation like this (you can have additional lines, too) and the SIM card sizes of the 4G LTE phone on L1 and the new smartphone you are ordering are the same size:
L1: UDP 4G LTE phone Yes or No
L2: UDP 3G or 4G LTE phone Yes
1) Have a 4G LTE phone active on UDP Line 1before you order;
2) Through*Verizon online, order the new smartphone UDP Line 1 wants using UDP Line 2's upgrade on UDP Line 2, picking the 2GB data plan for UDP Line 2 and have it*shipped to homenot shipped to store*DO NOT EVER SELECT A MORE EVERYTHING PLAN - if that is your only option, switch browsers or try ordering through the iconic portal or the comcast link.;
3) When the new smartphone arrives, remove the SIM card it ships with*without turning it on or plugging it in; and
4) Place the 4G LTE SIM card that is currently active on UDP Line 1 into the new smartphone and turn it on.
The result is that UDP Line 2's contract will be extended by 2 years and both lines will keep UDP.*You can NEVER use the subsidized phone on the UDP line it was ordered on. NEVER
