Is Jellybean on your Sprint Galaxy S3 yet?
quick question: I get poor reception at work, but have great wifi. It will take the update over wifi even if on the roaming partner, right? I see my wifi download arrow on quite a bit since yesterday. Would it download in the background, THEN notify me? Or it notifies then downloads?
Waiting for the OTA, but might need to root to get fully satisfied.
I was under the impression that you must have your ext sd card formatted FAT32. Is this still the assumption? Does wiping the card of all data except the update get around this problem. Mine is a San Disk 64 gb class 10 card, and I put the update in the root directory, along side all my media storage folders. When I tried to install the update from stock recovery, I got an error "E: failed to mount /sdcard (invalid argument)" as soon as I tried the boot from external storage option in stock recovery. I posted my problem and was told that most likely my card was pre formatted exFat and I need to buy a stand alone card reader to reformat the card to FAT 32. However looking through all the posts since Friday I see barely a mention of other folks having this problem. Help! That huge zip file is just sitting there not being unpacked and installed. And this Google services framework thing hasn't worked out for me yet. Are you supposed to clear data, force stop, then restart phone? Or check for samsung software updates first? Any direction would be appreciated
S3 on Sprint - 16gb pebble blue + 64
I saw a post about that on XDA. I think he said he formatted the card FAT32 and it worked for him.
I think that's what it said, but not sure. Sorry.
Qbking77 has YouTube with the file to update your S3. If you haven't received it yet just go do it manually.
Keep trying! I did the Framework trick 3 times and IT CAME FINALLY!
New York, NY- Hurricane Sandy
Settings
Applications Manager
Press All
Google Services Framework
Clear data
Press ok (DON'T PRESS ANYTHING ELSE)
Go back to settings
System Update- Samsung Software...
It should go live after pressing Check Now
If not, just repeat!
In Orange County, CA and can't get this update to save my life. Tried putting it on the SDcard and get that mounting error in recovery mode. Dark forces are aligning against jelly bean meeting my phone.
Yess updating as I type,This the way people who are still waiting to do it the OTA way!!!
NewOrleans by the way!!
Settings
Press All
Clear data
Go back to settings
Forgot to hit the reply with quote so I added it to my quote srry & BIG THANKS!!!
Settings
Press All
Clear data
Go back to settings
I was having trouble with skype so I uninstalled and deleted it. I rebooted the phone and when it started back up there was the JB update.
This was about 9pm out in mid-MI.
Maybe I should try installing skype again? LOL
I have a dumb question once you do the ota update does it clear all of your settings like folders and apps ect.. is everything going to be the same? or do you have to do a recovery sorry if i sound dumb??:-\
My S3 is 100% factory. The update did not clear or delete any of my apps.
RangelS25
