Issues So Far with GSIII
Update: I so far seem to have fixed the touch input delay by doing a hard reset.
The WiFi issue on the other hand is still there in force. I can't keep a constant WiFi connection on any access point no matter what proximity or signal strength. It doesn't seem to drop the connection but rather seems to be shutting off the WiFi radio and turning it back on immediately. I happened to be in the WiFi settings a couple times when it did it, it stated it was turning WiFi off, then promptly stated it was turning WiFi on again. It does this regardless of what the phone is doing. I can't watch any streaming content without interruption and large files are coin toss as to if they will download completely before the connection is killed and restarted. VERY ANNOYING :mad:
Edit: Spoke to soon, touch input delay is BACK!
The only Issue I have found that bugs me is using the headphone jack and bluetooth at the same time. I use the jack output podcast and music from the phone to the aux port on my car stereo. I also tie the bluetooth to the stereo for handsfree calling (no A2DP profile, only HFP).
With my Epic, when a call would phone in, it would pause whatever I am playing and transfer the call to bluetooth. When it finished, audio went back to the headphone jack.
With the S3, the call will come in over bluetooth, I hit answer, and then the phone tries to use the headphone jack as a headset instead of transfering the call to the bluetooth link. To fix it, I have the pull the aux cable to the jack. So far that I have seen there is nothing to force the call to use bluetooth (greys out the option). It is quite annoying as when I am finished with the call, I have to plug the aux cable back in, unlock the phone, and restart whatever I was listening to....
My headphone jack must be messed up because when I use the headphones with the mic (multiple pairs used) the person on the call says "are you fixing to take a bath?" then says it sounds exactly like a tub filling up with water. The hell is up with this?
I cannot get the Facebook calendar to sync to the calendar for the phone (birthdays, events, ect.)....anyone else?
gocoronago2021
