I'm part of the soak test and apparently it is a huge group this time. Havent had any issues so far; so the rest of the masses should get it soon.
By masses i mean being able to pull it from the server. Verizon historically has pushed to limited non-soak users as another sampling of a control before opening up the servers.
Verizon has it posted on their website that it is currently being pushed out in phases and will be available to pull next week for anyone who hasn't received it. My guess is that it's done this way to better handle the server load.
Sent from my Droid RAZR MAXX using Tapatalk2
If I got the x-mas leak and am currently still running on that 4.1.2, will I still be getting an update? NYC metro area
Try this:
Go to Google framework services under app manager clear cache/data, force close. Check for update. Retry a couple times if it doesn't work the first time. Let us know if you had luck with it. Sometimes, it just hasn't been released in your block and no way around that.
Sent from my Xoom using Android Central Forums
As long as it's charging, you're good to go. They only tell you to have at least 50% battery in case you're trying to update without being plugged into a power supply.
