Jelly bean ota - who got it?
Just did a framework clear and it came in! Try it doesn't hurt.
How do you do that? I've never heard of it... :confused:
-E- Nevermind.
Settings > Apps > All > Google Services Framework > Clear data.
Let's try it....
-EE- Didn't work. Will try again in a little bit
Tried it again, and rebooted this time. Still nothing. :'(
Tried the force stop > clear > check
no luck.
We will never know if one has anything to do with the other, it just gives me something else to do instead of hitting that stupid check now button all the time
went through the same steps listed above with force stop and clearing the framework. Nada here.
This is from a different post idk if is right
" Remember guys, OTA updates are not based on region at all. It doesn't matter where you live. Google's GOTA servers pick phones at random, and updates roll out slowly over about 7 days"
Ok this sucks. I got the notification to download it but it says Via Wi-Fi only until Jul 13. Since I was on my wireless connection I connected to my work's WiFi and now it isn't showing downloading.:( Sure hope that my work is not blocking the Google server.
Edit: Mine shows 144.9 MB as the file size compared to hawon's post earlier.
Just got my notification...have to wait till I get home from to do and install... yay! I'm in CT, USA if it matters...
Glad that my work wifi is not blocking Google's server. Updating now, yay! :D
I just realized that it is 144MB for the yakju builds and probably 147MB for the takju builds. Guessing for Wallet being included.
Got it. Tried Google Framework -> Force Stop -> Clear and the check update.
Its downloading now.
New York
Just got in here in Northern VA.
Did the framework trick, no update.
Did it again right after, Update found.
Something must have just broke free. Seems like a lot of people got it all of a sudden.
liquidsnake757
