Jellybean 4.1.2 available now at kies for att skyrocket
I updated my skyrocket and it's messed up now. Turns on then off, on then off. Keeps doing it over and over. Don't know what to do. Any suggestions?
I have the Galaxy Skyrocket and had no issues with it before the update to jelly bean software. Now 3 days after the update it takes 8 hours for it to fully charge the battery and drains quicker than before and has been freezing and force closing the "touch wiz" it uses now. Any ideas of what could be wrong?
I have Pantech Flex P8010 android 4.0.4 I whant to update it but I cannt what soft I must use ? haw i Can update it ? can you halp me ?
You're not in the right forum, but what I can say is if you look under Settings>About Phone, there should be a section where you can search for updates. Incidentally, I did a quick search, and there should already be a Jelly Bean update for your device available:
Update the Software for the Pantech Flex (P8010) using Easy Experience - AT&T Wireless Support?
AT&T's Pantech Flex to receive Jelly Bean update starting today | PhoneDog
the superuser on your phone means u ve root acess. please i think he want to if upgrading will unroot the phone or the phone will still be rooted.
I am not a superuser so I can't answer your question, but under the firmware instruction states that your SR cannot be rooted or altered in any way!! Bascially it states that your phone has got to be stock. The Firmware upgrade # is SGH-I727 Version.12.11.02.01. At 10:42pm it is now complete & booting up to Jellybean & optimizing all the apps. Good Luck.
I have incresed my system memory to 4 GB using odin. . . . but now I can upgrade my andriod using kies!
can any one help????
RangelS25
