Joban's Kernel 2.08 (Overclock, CM7 2.3.7 etc..) **Gyro Fixed**
Status
Not open for further replies.
Re: Joban's Kernel 2.08 (Overclock, CM7 2.3.7 etc..) **Gyro Fixed
Hi Everyone
I have a LG Thrive (P506) and I installed the Cyanogem mod 7.2.0 and my color was all wrong and I installed the joban 2.08 but my screen only shows the LG icon when I turn on after this my screen keeps all dark but sometimes if I touch the screen it vibrates so I think it's working, but I can't see anything.
Can anyone help me?
thanks
Hi Everyone
Can anyone help me?
thanks
Try doing a factory reset (Hold Volume Up + Power + Home) It clears the cache and data which can be issue if you flash a new ROM. If you have CWM then wipe cache and data and reboot. Restore from a backup if that doesn't help.
Hi Everyone
Can anyone help me?
thanks
I have CWM Recovery v3.1.0.0, I tried wiping both data and the cache but nothing changed, and the system says it can't find my backup that i did before I flashed the phone with rom manager
I don't think that rom is being hosted anymore, unless it's hidden somewhere on that forum but the links on the first page are dead.
I didn't find any link and went on all pages on that topic
Thanks for trying to help
Does this kernel support Ext 2/3/4??
Thanks!
Ok man ill help ya out, what you wanna do is factory reset your phone, clear dalvik cache, and clear cache....
Then get this file on your sd card and flash this with Joban's Kernal... (Its a mirror of Cyanogen mod .32 Kernal)
I believe the reason you're having these problems is because you flashed the wrong kernal/rom... prolly .35 instead of , .32.... So what you do is click this link, a pick the first download. Then copy to SD card, and go into CWM Recovery, and flash the files.
Let me know if it works for ya-it should.
CyanogenMod Mirror Network - Powered by TDRevolution
(cm_p500_full-31.zip)
So just curious are there any roms that I can flash since Im on the stock gb update for Phoenix with nbb and on .35 kernal
Sent from my LG-P505 using Tapatalk
I had the Same EXACT PROBLEM, so listen closely and go to this link...
Do what you normally do, It WILL work. I have no doubt. I promise.:cool:
Well Itried but it didin't work, my colocr are still messed up but you're right my kernel changed to .35, can I change that back?
I also tried with the full-33. zip but nothing
You promised :p
What can I do now?
Thanks
Oathkeeper, none of the p500 roms will work currently with the phoenix. We need a modified stock kernel and/or a cm7 kernel on .35 to be able to flash whatever we want. Honestly, i have a sgs2 skyrocket myself and i'm loving it. I have it oc'ed to 1.72 ghz using faux 0.9 kernel and it is just sweet. But back on topic, i gave my phoenix to my girlfriend and i may have a few suggestions for you.
1. Root and then use set cpu to change the governor to performance.(not really overclocking but it does help)
2. Use a custom launcher (go launcher and adw launcher ex are my fav.)
3. Definately use link2sd.(I installed about 7 games and like 20 apps on the phoenix and theres still 120mb left internally)
4. Look into UOT Kitchen. This thing is wicked and even lets you fully theme out your STOCK ROM.(Custom battery icon,custom icon packs for everything,custom lockscreen,you name it)
These are just some suggestions as i have pretty much given up on this kernel and just made gingerbread totally customized for my girlfriend.(She has a PAW for a battery icon)LOL
You promised :p
What can I do now?
Thanks
Ok, sorry it didn't work... I had THE SAME EXACT PROBLEM! so i know its the kernal. You need to flash a .32 kernal/rom in order for Joban's kernal to work properly, because Joban's kernal is not made for a .35 kernal. You MUST have a .32.
SORRY WRONG LINK!!!!!!!!!!!!!!!!!!!!!!! its this one!
http://search.4shared.com/q/CCAD/1/cosmIcEXperia_v3.5
or
http://www.4shared.com/zip/1l0TC4i2/CosmIcEXperia_v35.htm
IT IS THE ONE I HAVE, I MIXED LINKS UP SORRY!
Try and flash it, but don't flash jobans kernal, but reboot it and see if it can go to the home screen with the bad blue and green color problem... After it does, hold power button and shutdown device. Go to CWM and flash Joban's Kernal, then it should work fine.
THE PROBLEM: You need to get a .32 kernal, a .35 won't work... it will just stay at the lg logo or screen will go black after a while; so its a must that your LG THRIVE has a .32 kernal flashed with Joban's kernal.
QUICK NOTE*-Maybe try this,
-Make a backup of your SD on your computer, then partition your sd card, format sd card, clear cache, clear dalvik cache, put the cyanogen mod 7 back on SD card as well as Joban's Kernal, and reflash the Cyanogen Mod and reboot-if it works reboot phone once more and flash Joban's kernal... success.
UPDATE: time for a new phone! Ill release my .35 kernel but only for those on the stock rom and running new baseband! But the wifi doesnt work and im not gonna waste my time n it either so if you want 35 that bad then deal with it. And im also done with this phone too. Sorry guys but looks like im gonna have to say bye.
Well I tried but it didin't work, my colocr are still messed up but you're right my kernel changed to .35, can I change that back?
You promised :p
What can I do now?
Thanks
cosmIcEXperia_v3.5 - 4shared.com download free - 1
or
CosmIcEXperia_v3.5.zip - 4shared.com - online file sharing and storage - download
It worked with the Experia one all colored up thanks
Do you think I should stay with that one or should I try again the CM7?
One more I know this isn't the place for that but where's the android market, please tell me that it works with custom roms
Thanks again
Joban Please release your source code as well as the kernel so that we don't have to redo the work you have already done.
Reactions: electech
yo, i felt stupid when i couldnt find it either, but right underneath the original link to the A8 version, it says alternate link:
Free Online Storage & File Upload with FileServe
Bye Joban, thanks for all the work you have done for us, enjoy your new phone!
Reactions: fae_jr
Status
LordDAXVader
