JRummy Remix
im running this rom and i absolutely love it. i have had no problems with it at all everything is running 100% smooth for me
Are guys noticing that the bottom of the setcpu widget is cut off. Idk why but mine is.
I haven't used the setcpu widget in a long time but from what I remember mine looks fine.
doe anyone know why when i try to remove an app or a feature with the custom scripts in terminal emulator, i get the following message:
mount: permission denied (are you root?)
it's telling me it can't access files i'm requesting to delete because i'm not rooted i guess. of course i'm rooted if i'm running JRummy v.6
any ideas?
Was it on the bottom of the screen? because I just noticed my pure calendar is getting cut off when on the bottom of the screen
any ideas?
Have you downloaded and extracted the goodies?
I had some issues with the instructions on the thread on how to use scripts.
Once you have the goodies folder on the root of your sd card open the terminal emulator.
Type su and press enter
on the next line type the name of the script (ie: rmfacebook) and press enter
I had the problem because on the thread for this ROM it shows a dash in front of everything like -rmfacebook.
Hope this helps
Nope. Its on the top. I can't figure out why it is doing it either. I wiped and reinstalled but still cuts the bottom off. I'm thinking it could be an issue with the cyan version. Once he released the red version then I will try that one and see if it works. Time will tell haha. That seems to be my quote lately. One thing that I would love to be implemented in this rom would be scrollable Widgets but that's probably something cyanogen would have implement.
Hope this helps
i need to have the goodies folder installed to run the preinstalled scripts? what is su? i've never used the terminal or adb (sp?) before, so i'm new to issuing commands on the droid.
That is one of the biggest reason why I want the Desire rom is for the scrollable widgets.
i dont know what is worse, to not have ever experienced them but really really want them or to have experienced them but not on a fully functional/stable rom haha. 1 question though (before this gets completely off topic), how is the over stability of the widgets in the desire rom. i know you have mentioned the weather animation widgets have some issues but what about all of the other widgets that come with it. are they exactly the same as the desire/incredible or are they adaptions of them where they aren't 100% exact?
for the most part they all work footprints wont take pics but they work and i love them. now back on topic
See you can download the goodies from here. Extract the file to your SD Card. Terminal Emulator comes pre installed. SU if i'm not mistaken just gives you superuser permission. Once you do that its very easy to run the scripts.
su <ENTER>
"name of script" <Enter>
If you have multiple scripts just keep entering in the script name. Once you are done just close the TermEmu
i extracted the goodies file to my sd card and ran the terminal emulator with the su permission, and got no file or directory..permission denied..are u root? along with credit to starscream...any ideas what i did wrong
ecomranx12
