JT Super Clean Rom available on Rom Manager
When anyone finds a theme that would work with this ROM, post it here if you can! I'm hesitating to apply a theme for this reason. :)
If anyone is looking for the deodexed version of the stock music player it can be found here:
Stock Deodexed Music Player - xda-developers
Download zip file and place on your sd card
Open Rom Manager and choose reboot into recovery
Use volume to toggle up and down power button to select once in CWM
Select install zip from sd card
Select choose zip from sdcard
Find file stockmusic.zip (If you downloaded it with your phone look in the download folder otherwise it should be wherever you placed it with your computer)
Select stockmusic.zip
Scroll to Yes - Install stockmusic.zip
Wait for the install to finish
Reboot
Just a quick note, if you are wanting to use the drop down from the lock screen you will need to have the puzzle lock screen installed.
Reboot
Thank you, I'll have to try this when I get home later. I just liked the drop down on the lock screen since I used it while driving everyday.
Sent from my SCH-I500 using Tapatalk
Or if widgetlocker is worth it I might get it and just put the music player widget on my lock screen.
Yeah I'm in the same boat with you, plus I kinda liked The stock player. If you need any help or the zip PM me.
Any chances of there being a version with ADW and one with Launcher Pro (Plus)?
If you had LP+ you can put it back on, by either installing the code again or you can restore your LP backup. I wish it woulda came with LP too.
I installed the jt rom and non-voodoo kernal. Works great, in case i wanted to go back to stock rom and kernal for froyo update. How would i do that? I have my stock rom backed up with rom manager, but how do i get stock kernel back?
Sent on SGS Fascinate using Tapatalk
It's my understanding that we'll be able to flash 2.2 when it comes out, via CWM. So I wouldn't worry too much :)
People with the rom and kernel should be fine.
I'd also wait for someone to make a cleaned up Froyo. We all know Samsung sucks at making software, and that Verizon will only make it worse with bloat. I wouldn't touch the OTA myself.
Mr2Shorty3
