[Kernel] Genocide 1.2GHz Froyo DK28/EB13 RFS/EXT4
Are they working on getting it to run on eb13? I am sure I will be on gingerbread before they get it.
sweet. the first time i flashed this kernel, after i unlocked my phone, it would go back through the boot animation. but the second time i flashed this, it was perfect. must've been a bad flash the first time
So I'm a bit confused what should be done in setcpu to tke advantage of undervolting and battery life. The xda post says "First I suggest that you use SetCPU to lock in 1GHz to take advantage of the slight undervolt"
Does that mean I should set Max and Min to 1Ghz?
Sent from my SPH-D700 using Tapatalk
From what I read over at OP was setting: Conservative. Min 100000 Max 1000000. It sounds like you can play with the min setting just as long as you don't go over 1000000 it will use the undervolt. The phone does become laggy and somewhat unstable if you drop it down too low.
I'm at 14 hours now since full charge on the undervolt. Played 1 hr or so of Angry Birds, a bunch of surfing wifi/3g/4g and posted a bunch on here while surfing and I'm at about 30 percent left on the stock battery... Not bad at all.
I'm also at 1GHz, and definitely noticed a battery improvement. Getting about 1% battery drain per hour at idle.
Damn this is sooo sweet and its only the beginning of the wonders that will be done with this phone. I am so happy.
first of all thanks for playing with my kernel. i'm glad it's working wonderfully for everyone.
second please read my OP on xda...it has all the questions so far answered in it and should clear up a lot of confusion and 'not exactly correct' advice in this thread
if anyone has any questions or problems please let me know over on xda.
thanks
thanks
ziing
hellbent.cc admin
I don't know where you people get the balls to try and pull this off without giving credit. Rodd on the Viper team (with a little help from myself and the rest of the team) crafted this kernel from the EB13 source and you people couldn't thank/give credit? Also, I am the owner of HELLBENTdotCC and gave absolutely NO permission to link to my site to download this kernel. Remove any and all links to HELLBENTdotCC from this thread IMMEDIATELY!
You didn't stay up till 4am testing many many builds of this kernel - I did, Rodd did and the rest of the Viper team did. If you want some street cred roll your own damn kernel.
We have Froyo DK28 overclock! Better late than never right?
Source: [KERNEL][GPL]Genocide 1.2GhzOC EB13 Kernel v0.1a (DK28 Compatible) - xda-developers
Features
1.2GHz overclock
1GHz 25mV undervolt
DK28 and EB13 compatible
RFS & EXT4 compatible
Files
ocide_1.2GHzOC_EB13_Kernel_v0.1a.zip"]Kernel download[/URL]
Free SetCPU alternative: search "OverclockWidget (Need Root)" in the Market
Instructions
Download kernel zip file, place on your SD card, and flash via Clockwork
Setting speed to 1GHz = undervolt, but no overclock (better battery)
Setting speed to 1.2 GHz = overclock, but no undervolt (more speed)
No problem, link removed. I usually don't post direct links, but members were approaching me asking where the download link was (I realize it is clearly listed in the XDA thread, but I was approached nonetheless). My apologies.
And just to clarify things, nobody here was taking credit for your work. This thread is simply here to notify our members that this kernel is available. If you look at our many ROM threads in this forum, this is the same format that is used to notify them about ROMs as well (there are no direct download links in those threads; this was an exception for the reason stated above). Usually we don't make threads to notify members about kernels alone, but since this is the first overclocked DK28/EB13 kernel, it was merited.
Myself and our members have nothing but the upmost respect for your work. I will add a credit to the first post if you still feel I am misrepresenting the kernel's author.
I don't think anyone has a problem with linking over to xda site or even if you had a link to our site and saying "I did not create this SOANDSO did over @TeamViper" that kinda thing. teamviper is pretty tight so one of us sees something that another one of us worked hard on and it seems like they arent getting the credit they deserve everyone just pounces :)
I can totally understand that reaction if someone thought a team member's work was being stolen. And if you're not familiar with our ROM/kernel alert threads, I can also see how it may be confusing. Our members are familiar with them, and understand that the "Source" link in the OP is where the work originated.
The link to XDA in the OP helps direct users to you, and build your fan base, which I would like to do to help keep your work going. I and the rest of AC look forward to what Team Viper will do with EB13.
Im pretty new to this rom thing. But If it helps, im loving VIPER teams work
Reactions: S0ckM0nk3y
@teamviper, we all here appreciate your work. After months of no true custom kernels it was so nice to finally have something. I did also stop by and voice my opinion of the kernel earlier in the day which Rodderik responded to. Thanks again for all of TeamVipers work.
I am writing as a member of both sites. I personally use more info out of Android Central because of my lack of technical expertise. I read XDA also, but many of the forums and instructions are beyond my expertise.
But I cross reference and research anything possible which increases my knowledge and ease of use. And I am all aware of Viper's team approach and the work they do which helps many there, here, and other developers.
As an example, I am watching these threads. I do not know how this new kernel will affect my phone, do I download and update? Do I wait for a new rom with everything included from the new source to flash over what I am currently running?
I also respect XDA forums and developers work by not going in and asking these foolish types of questions. I just keep reading, watching, and learning.
So if credit was not allegedly shown, it was not a slap. I truly believe the mods in this forum read and respond on both, and try to direct us to the info that we need now or will in the future and hopefully allow you to do what you do without a lot of time and effort spent on educating people like myself.
how you getting such an improvment? mine went from 1500s to 1700s
Well I was at 1930 ish before. From my understanding, the quadrant score is based on a ton of factors on your phone, many of which are user customized so its possible that I'm just running a leaner ROM or something like that. At any rate, the increase was quite welcomed. this phone keeps getting radder
dumpsterrentals89
