Is the tethering I see in the wireless and network settings the same as Verizon 3G Hotspot or is it something free within the update?1. some of the vzw are missing, but you can still download them from the market under the vzw tab.
2. yes, it should have given you root access.
3. wireless 3G hotspot is not free... you can use it if you pay vzw to do so.
1 - It gets rid of most Verizon apps, including VZNavigator and My Verizon. (Although you can get them in the market)
2 - It comes with Superuser access, yes.
3 - Not 100% on that one, never tried it. But I believe Verizon charges for it. Just download WiFi tether from the Market.
#3 There was a posting on the earlier pages either here or at XDA, actually I think it was posted there then copied here, but anyways it says that there is something built built into this ROM that allows VZW to monitor unauthorized tethering. Not sure if it is accurate or not, but since it was posted by the OP on XDA I am tempted to believe it.
Is the tethering I see in the wireless and network settings the same as Verizon 3G Hotspot or is it something free within the update?1 - It gets rid of most Verizon apps, including VZNavigator and My Verizon. (Although you can get them in the market)
How long should the initial reboot take? I have been waiting for a while now and am getting concerned.![]()
A Noob Question: Can I flash a Superclean Rom on top of this and do I have to do a Cache wipe and factory reset in CWM first.
Rooted, DL09, 2.2.1, SCH-I500.DL30
what's sup forum ? the only problems i'm having so far is with *228 my phone won't restart and with backup assistant. can anybody help me with this ?
That what I was getting last night as well and couldn't get it to go away so I ended up going back to stock DL09 and starting over and wiping data/cache about 3 types each for good measure.
Works fine for me. If you're using your phones web browser, don't do that. Use your PC and then transfer to your SD card.
Works for me
Lol! Yep, I had him about 2 months ago now.
@Cory- you ever get that samsung keypad keypress sounds thing figured out? If you haven't, it looks like if you turn down System Volume in Sound Settings, it gets rid of that along with the annoying boot/shutdown sounds
ha didn't know the preview trick in the app drawer. So we have:
- previews in app drawer
- pressing back and the power button takes screen shots
- long pressing on notification bar and dragging left or right adjusts display brightness
The screen shot trick is an AWESOME find!
did i miss something here , why dont you just shut down audible touch tones/selection down?
pages and pages back someone had an issue with the domain key being absent... I installed the keyboard Cory mentioned (Smart Keyboard Pro) and this is an option:
"Persistent domain key - Always display the doman (.com) key"
Maybe that is helpful? Maybe not?!
