sushiguy732
- Jan 11, 2011
- 1,351
- 46
- 0
yeah he deserves a thank button hit for that --Click to thank him
Done! And thank you for the reminder!
Is anyone having an issue where the screen will not stay on while charging. The option to have it on is no longer in the settings > applications menu...
Is there another way folks are getting the screen to stay on while plugged in...
Thanks
First off thanks everyone on here for all the help
I followed the instuctions from page 1 and have froyo now. One question i do have and was not apart to the instructions, do i need to clear cache partition?I seen someone talking about it but wonder what will it actually do if i do clear it?
my only issues so far is I cant read my email cause it says its too big and my battery also seems to drain faster.
A seperate question, I use advanced task killer to close apps, how come apps I know I have not used always seem to show up when i run task killer?
Still cannot get cwm to backup. Tried using rom manager. It loaded the green cwm and froze when backing up. Pulled battery and the red cwm loaded, it froze also when backing up. Not that big of a deal since titanium backup is backing up of my apps.
Sent from my SCH-I500 using Tapatalk
is anyones phone runnning warmer the usaul?
Quick question, not sure if this has been mentioned already, I apologize if it has, but has anybody had problems keeping red cwm after flashing DL30? Mine keeps going back to green cwm, (I assume it's the old green cwm), and I'm having to constantly re-push red cwm through odin in order to flash the new roms/themes for DL30. Thanks for the help!
Are you talking about when you boot into CW using ROM Manger, or are you talking about when you do the volume up/down + power combo?
I'm talking about the volume up/down + power combo, I've never really tried it from ROM Manager
Yeah but only because I haven't stopped playing with it. Seriously though, it isn't really. Are you using a task killer, besides the one that's built in? If so, that could be the source of your problem
no i am not and i dont touch the one with super manager.. and ur right i cant stop playing with it..and for the life of me i can not get red cwm i keep flashing it then when i start up it gets stuck at the samsung screen is there a new one coming soon. i have the sd card that came with the phone should i do app2sd?
Why do you need red. Does the green not let you flash?
no it did...i thought red was better also i just installed sc.8 and cant down load handcent was it removed from market and should i do app2sd what are the benefitds to it
i lost red when i flashed new cwm ,,,why do you need red clockwork why dont you just flash it from green?
Hmmm. Not sure if you followed my procedure and downloads, or someone else's, but I boot into red each time.
Oh wait, did you say you do want voodoo again,,,,did you properly disable lag fix before you flashed froyo?
