Leaked DL30 Froyo Build Available NOW! (Includes Full Instructions: Updated 2/5)
Status
Not open for further replies.
I knew as soon as I said it I should have kept this to myself :-[
lol no worries, I was wondering if I had missed something or had it hidden via Launcher Pro. but I definitely appreciate that this leak doesn't have a lot of bloat on it.
I installed Froyo last night and everything seems to be ok. I am curious is there any way to update the market place? If yes, how?
I don't miss the bloat either. Went in to freeze in TBU and was like wow. Froze the touchwiz clocks and live wallpapers and the others y'all mentioned. I like this a lot.
Thanks to all of you who put in all the time to get us all up and running.
Sent from my Froyo Fascinate using Tapatalk.
Well, took the plunge and got the FC loop, then the digital voice telling me to update drivers and now I have froyo. It easiest to just flash to DL09 first.
Heck with VM, just run YouMail. Is customizable and you can access it via your internet connection instead of calling VM. and fully functional with 2.2
Need to figure out a way to turn off sound of battery getting too low, that can be annoying. EDIT: found those sounds, and changed them to OLD.
Also, can anyone tell me where to find that 3G hotspot app so I can move it to the SD?
Anyone else notice the Gallery app is not as smooth as before? I think it is just STUPID FAST now.
Definitely worth the upgrade, THANX
Edit: is the program listed as in the lib file as hotspot_event_monitoring.ko the hotspot monitor program?
If we remove this, can we use wifi barnicle? Did anyone notice the apps in this ROM are from Aug of 08?
I can't find the mobile.apk. That's what it used to be called, but no matter where I look I can't find it. Clearly it's somewhere.
The gallery seems smooth and wicked fast.
Good find on the battery sound. Maybe I can find the annoying Samsung KB key click sound.
It uses the same one the Stock Android keyboard uses, if that helps you any Cory.
Makes sense. That's the only thing I haven't been able to remove.
As far as people experiencing FC's when pressing the VM button on the dialer, that is because there is no VVM app with this release. Official will most certainly have it though.
okay --- very stupid question guys.. i'm totally bone stock dl09 with never having flashed at all. i'm a complete noob to all this. if i follow the instructions on post 1- will i have froyo? or is there something that i have to do prior to post 1?
thanks guys
Ah! Yes! I forgot that voicemail button goes to Visual Voicemail. For some reason I kept thinking it dialed your VM access number. Thanks!
thanks guys
Yes. This leak is a Froyo leak. DL30 is just the build number.
Status
paulmloucks
