Leaked DL30 Froyo Build Available NOW! (Includes Full Instructions: Updated 2/5)
Status
Not open for further replies.
At step 13. Odin3 is at "<ID:01003>recovery.bin".
Phone is still at "Downloading..... Do not turn off targert".
Has been at this state for about 10mins. now. Am I becoming impatient, or is something wrong?
Yes - this step should take 1 minute or less. Did you use the PDA button or the PHONE button in ODIN? Also, what state was your phone in when you first started the procedure from the top? For example, fresh install of DJ09?
Had DL09 since it came out. Phone screen finally went red. Odin came back failed after about 15min. Phone boots back to screen with a small phone and computer icon on it with a yellow triangle in between. Any ideas?
The next thing that should happen after step 13 is this:
14.) Phone will power down when finished.
15.) Remove USB cable.
16.) Reinsert battery.
17.) Press & hold the volume up and down buttons at the same time. Do not let go. Now press and hold the power button. You will see the Samsung logo display, disappear, and then reappear. Now let go of all buttons.
Are you saying that instead of 14, it just went to a red menu? Was your battery in or out of the phone while you were flashing with ODIN?
Also, was this phone rooted previously?
Checked all cable connections. Tried one more time. Same result. Stuck with phone at downloading, Odin at recovery.bin. If it continues to plays out the same way, phone will shut off in about 10mins with a failed Odin response. Then if I put battery back and try to reboot, I would expect to get the phone, "yellow triangle !", computer icons again. Not sure how to preceed from here(if I even can), gulp!
Yes I'm rooted. Yes, battery was/is out. Phone did not go to red menu, just an entire red screen. Then it powered down and Odin came back failed.
Alright, see if my original procedure with the old ClockworkMod works for you instead: Click here. If at all possible, I would start by flashing the DJO9.tar.md5 file with ODIN.
Can you still get to download mode?
Sent from my SCH-I500 using Tapatalk
P.S. - if you have been using the same USB port over and over, I would also try a different one. Make sure you also restart ODIN each time you flash with it.
Cory, you are awesome with your quick feedback. Thanks, I will give your suggestions a try. And don't take this the wrong way, but hope I'm not posting back here again in the very near future.
And to DroidXcon..... Yes, I can still get to download mode. It's about the only thing I can do right now. Why? What are you thinking ???
Do you happen to have an anti virus on?
Reactions: kalnel#WN
At step #20, when I select install zip from sd card my screen goes black. Do I just wait? Shouldn't I be able to select zip from sd card immediately?
Back button is select. Press home button again to wake the screen up
Rebooting now! Thanks. Its kinda scary messing around with this phone when I don't really know what I'm doing, but I can't seem to leave it alone. Thanks for all the info on this site. If you can read you can have froyo.
Status
angelag5098
